higher mph speedometer
Old Nov 7, 2006 | 07:49 PM
93hondablk's Avatar
93hondablk
gtr
Default higher mph speedometer
I want to get a new speedometer that reads more than 125.
I can't tell how fast I'm going after 125.
Are their any speedometers that fit the crx that read more than 125mph?
Old Nov 7, 2006 | 07:59 PM
Hondelso's Avatar
Hondelso
i hope you don't do that in the streets! as for an aftermarket speedo gauge i have no idea. you could always swap out and rewire to a different cluster. s2k cluster (planning on swapping that in mine). just need to figure the vss part. the wiring is so-so.
Old Nov 7, 2006 | 09:08 PM
Kai's Avatar
Kai
Rotorphile.
If you are going over 125, you either have to be on a drag strip where you can get a timeslip to tell you how fast you were going, or on a racetrack where you should know how how to handle the car without knowing actual land speed. Closed.
