EF9 JDM SiR front end questions
I have tried to search this out with no luck-
I am trying to figure out some solid info on the differences between the JDM Sir and the USDM front ends. I know the fenders are the same with only the side markers being the difference. I also know the middle filler piece is different and the JDM head lights use a single H4H bulb. What I am not clear on is as follows...
Is the JDM SiR hoods longer than the USDM hood in the middle (between the lights)?
Are the JDM SiR headlights taller than the USDM lights? What I am meaning by this is; do the JDM lights sit in the same place at the bottom like the USDM lights but have a taller top to fill the gap in the SiR hood?
Will the JDM SiR headlights fit with the USDM middle filler piece while using a JDM SiR hood (If so I know there will be a middle gap in between the head lights)?
Thanks in advance to the JDM Buffs!
I am talking about the JDM SiR headlights ( also the housing if that needs to be changed also)
heres the link to the ones I'm talking about.
http://www.passwordjdm.com/product.a...For=&PT_ID=235
Thanks for your response
Ask password, I know the guys that work there, they wont sell you something that wont fit.
Just contact them, and tell them what you have, and if what you want will bolt in, and fit without modification.
head lights look bigger in the upper inner cornners, hoping u know that the bumper has a second opening right under the black molding line, turn signals are longer and streched around the bumper.
srry if your talking bout da civic
