help.crx problem
Old Jan 17, 2007 | 07:23 AM
jnicknut's Avatar
jnicknut
Banned
Default help.crx problem
i just got done putting a new intake mani and aem fuel rail on my 89 crx.i started it up and the rpms jumped up to redline i turned it off and started it a couple more times now the idle is jumping from 2 to 4000 rpms.any reasons why?
Old Jan 17, 2007 | 10:55 AM
jnicknut's Avatar
jnicknut
Banned
anyone?
Old Jan 17, 2007 | 10:58 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Vacuum leak. Check the intake manifold gasket and all the hoses.
Old Jan 17, 2007 | 11:01 AM
jnicknut's Avatar
jnicknut
Banned
is there a good way to do that.i tried feelin for any air anywhere but cant find a leak.
Old Jan 17, 2007 | 12:50 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
You gotta check the hoses and such
But seeing as the problem came after the manifold installation....it prolly didnt get sealed right..Redo it or put the old one back on
Old Jan 17, 2007 | 01:41 PM
Provocateur
On permanent hiatus
Were both of the gasket mating surfaces between the head and manifold completely flat and clear of old gasket that may have stuck to it?
Old Jan 17, 2007 | 08:54 PM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
If the above mentioned things are checked and seem to be in good order, then an old/faulty/damaged IACV could be part of the problem.
Also check for leaks at the mating surface for the throttle body-to-intake manifold.
Old Jan 18, 2007 | 07:32 AM
18crx's Avatar
18crx
stock booster
did u go from dpfi to mpfi. and only change the manifold and injectors
Old Jan 18, 2007 | 09:02 AM
jnicknut's Avatar
jnicknut
Banned
Problem Fixed Thanks For All Ur Help
