B16A O2 sensor wires?
USAF C-17 Crewchief
Question, I have a 91 CRX Si with a B16A swap, when I got the car, it had a header, with one oxygen sensor in the colector pipe.
I know that the JDM stock exhaust manifolds come with 2 oxy sensors, so I got a JDM manifold, and 2 oxygen sensors, now I need to know how to wire them?
Since I only know where one oxygen sensor wire is, what do I do?
Can anoyone help me out?
USAF C-17 Crewchief
hmmmm I just found out today that OBD0 only has one sensor....
So what do I do if I want to run the JDM manifod with 2 sensors?
By the way I have OBD0
USAF C-17 Crewchief
I have 2 good sensors, can I just use the good one to plug the hole?
Or will it mess it up?
The only thing I am worried about is, the manifold sensors are for 2 cylenders each, so I think like 1-3 and 2-4, is that bad if I am just measuring the content from 2 cylenders?
Will it read wrong?
I will do some research on the wideband setup, thanks for the info so far.
Will it read wrong?
USAF C-17 Crewchief
I just searched for a OBD0 to OBD1 conversion, and what I would need to do, and it says you convert from Two 1 wire oxygen sensors, to One 4 wire sensor?
I am kinda confused now?
Does anyone know how many OBD0 is suposed to hve?
Rotorphile.
USAF C-17 Crewchief
Ok, thanks.
I cant seem to find a wire diagram for a OBD0 ECU, I noticed there are a few wires that are not plugged in to the connector , just loose wires... I want to find out what they are, because I have a few codes I need to fix.
So if anyone can send me a link to a diagram that would be awesome.
