Best way to remove...
Old Jan 28, 2007 | 10:06 AM
theleprechaun's Avatar
theleprechaun
Default Best way to remove...
How the heck do I get the alternator pulley off my engine block, if I put it in reverse will that strain my tranny at all?
Old Jan 28, 2007 | 03:56 PM
bob01721's Avatar
bob01721
Uh... please correct me if I'm wrong, but isn't your alternator pulley on your alternator?
Old Jan 28, 2007 | 04:59 PM
theleprechaun
Default I was confused
I ment my crankshaft pulley, and I also forgot that forward or reverse have no effect on the crankshaft, at least not in holding the pulley in place.
I believe I haveto lock the flywheel and then get it off. So I'll do that after I remove the old block and can reach it.
Old Jan 28, 2007 | 05:44 PM
bob01721's Avatar
bob01721
There's a special tool for holding the crank pulley while you break the bolt free. Otherwise, an impact wrench will usually work.
As a last resort, some people have been known to put a strong breaker bar on the bolt head, rotate the bar (and pulley) to a point where it's safely wedged in place, and then bump the starter.
Old Jan 29, 2007 | 09:00 AM
Tankard's Avatar
Tankard
5th gear and get somebody to hold the brakes while you break it with a breaker bar. Never hold the pully itself(unless it's a tool designed for it), unless you want to break it. I broke mine the last time i took it off and had to buy another one, which was expensive because i could'nt find one at the junk yard. But, a very powerful impact is the best way. Mine is a whimp, when it comes to crankshaft pulley bolts.
Old Jan 29, 2007 | 07:44 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
use a 1/2 in or 1 in impact gun, the bolt will come right off
