Turbo feed/return lines
Old Aug 23, 2006 | 01:39 PM
Minho's Avatar
Minho
Default Turbo feed/return lines
My Turbo kit came in and im so enthused to get it into the car. THis is my frist time turbo charging a car I have put a super charger b4 but no turbos. One question is on a sohc ZC engine (Same as american D16a1) where is a good place to tap my oil feed and to put my oil return lines on this engine?
Old Aug 23, 2006 | 01:40 PM
Minho's Avatar
Minho
Im gonna take some pictures soon of the car and engine to post them on here
Old Aug 23, 2006 | 05:33 PM
t3t4delsol's Avatar
t3t4delsol
oil feed use the exsiting tap from the oil pressure sender located near the dizzy,
return feed, remove oil pan and drill an hole in that, either jb-weld the fitting on or weld it
Old Aug 23, 2006 | 07:10 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The oil return can be tapped from the oil pressure sensor (as mentioned) or you can use a oil filter sandwich adapter that has threaded ports for you to use for oil feed and gauges.
The return line is gravity fed, so it needs to go directly from the turbo into the oil pan without going back uphill.
Old Aug 24, 2006 | 11:45 AM
extensioncordy's Avatar
extensioncordy
EG6
the sohc zc is the same as the d16a6 the d16a1 is the same as the dohc zc
