b16a question
Old Aug 21, 2004 | 11:24 PM
Fire's Avatar
Fire
wanna run
Default b16a question
ok i wanted to know how i can tell if the b16 i bought was originally an automatic or a manual. Kai? any thoughts?
Old Aug 22, 2004 | 04:00 AM
Fire's Avatar
Fire
wanna run
anyone? also it is the 1st gen jdm...it came with a j1 5 speed but also came with a ecu for a auto...just wanting to know if my engine was for the auto or 5 speed. i hope there is a way to tell. I know the cams suck neways...bought new ones, but it is the compression ratio want to have from the 5 speed version B16a.
Old Aug 22, 2004 | 05:45 PM
ED9man's Avatar
ED9man
driver
I don't think there was an auto CRX SiR.
Maybe they sent you the wrong ECU with it.
Old Aug 22, 2004 | 07:12 PM
Fire's Avatar
Fire
wanna run
yeah they def sent the wrong ecu but remember the B16a 1st gens werent just in crxs. jdm integras too
Old Aug 23, 2004 | 12:09 AM
slammed91-hatch's Avatar
slammed91-hatch
the motor would not be designed to work with a specific tranny. The ecu is what would be different, definetely need to get one for a manual. I also don't think they made a b16a with an auto, but i'm not sure on that. but anyways, a motor is a motor and is not "designed" to work with a specific tranny.
Old Aug 23, 2004 | 01:34 AM
Fire's Avatar
Fire
wanna run
ACTUALLY the B16 that came with an auto tranny had smaller camshafts and not as much compression ratio :db:
Old Aug 23, 2004 | 10:46 AM
slammed91-hatch
prove it. what would the engine code be then?
Old Aug 23, 2004 | 12:12 PM
Civic2Scooby's Avatar
Civic2Scooby
the engine code would be B16A
and yes they had automatics, and yes they had a slightly lower hp.
Old Aug 23, 2004 | 12:18 PM
89crxinprogress's Avatar
89crxinprogress
but if he is replacing the cams he could use ones with a higher lift which would also raise compression right? then it wouldn't matter if it originally had and auto or manual tranny
Old Aug 23, 2004 | 12:19 PM
89crxinprogress
it would also raise hp
