Shifter and bushing install
I ordered an B&M short shiter and bushings for my 89 CRX DX. I was wondering how hard is it to install. I also want to know if anyone could give me some sort of idea on how to do it. If I had some sort of idea I will be able to do it. I curently have my stock exhaust in the trash and installing new parts. The shifter is exposed on the bottom of the car, so I figured I replace the shifter now.
It is really easy!!! Underneath where the shifter is you will need to remove both bars that are there. Look at your new parts and you willknow what to replace. One of the shift linkages go to the bllock, you will need to unbolt that linkage and again look at your replacement and you will know whta you have to replace.
Hope that helps in a nutshell.
