lowering question?
Old Aug 22, 2004 | 10:36 AM
Lm546's Avatar
Lm546
Default lowering question?
ok,
ill list what i had done thing tell you the prob. i put tokico illumni strust, RS*R spring, 2 in the front 1.6 in the rear and wheels and tires, and ingals camber kits all around. the problem is my car is lower on the drivers side than on the passenger and the springs did not drop right so it sits close to an inch higher in the front. i put them on awhile ago, i wanted to let them settle, but the problem in the 1.6 inches in the rear maybe dropped about 3/5-1 inch. and the 2 inches in the rear only dropped about 1 inch. the springs have settled and it is sitting wrong, i have not had an alignment done yet b/c i was waiting for the springs to settle, but i adjusted the wheels to sit straight so it is off by close enough. i just wanna know if there is anything i can do or if i just need to invest in new springs? thanks for any help you can offer.
Old Aug 22, 2004 | 02:02 PM
BadAzzCamaro's Avatar
BadAzzCamaro
Camaro Handler
I had that happen to me awhile ago. Just bought new springs and everything was fine.
