B16 swap question
I was wondering if anyone has ever heard of a CRX SiR having a 170hp motor? I know the SiR II does, but I heard that you can find a 170hp motor w/ cable trans for use in a 88-91 Civic/CRX. Any help would be appreciated.
I have not heard any SiR motor having 170,i thought only the b18c had those specs.I don't think any 16 stock is 170.
Have you even tried searching for any info,i did some and this is what i came up with.
http://hybrid2.honda-perf.org/tech/engine.html
Originally Posted by mistacee
.....I don't think any 16 stock is 170.
Have you even tried searching for any info,i did some and this is what i came up with.....
B16A second Gen 170hp
maybe you should try searching your self.....:fawk:
and to answer the original question, the only way you would get the 170 b16a with cable trans is if the cable trans was put onto the 170 motor. the civic and crx SiR were only offered with the 160hp first gen cable tranny b16a
The first generation B16A were rated at 160 PS. (roughly 160 HP)
The second generation B16A were rated at 170 PS. (roughly 170 HP)
Remember though that their octane level is higher than US standards.
yeah i just found out my roomate has a big drum of race fuel is the garage for his 10 sec nova so i am going to start skimming off him for a while.even so yes the b16 has a 160 hp,and the 99-00 si had a 170.u are still going to pull any newer si with more hp if there both stock.
Originally Posted by ED9man
the newer Si had 160 also.
B16a's will run just fine with 91 octane.
I run mine on 94 octane without any problems what so ever.....
higher octane doesnt always mean higher horsepower anyway.
