Need Help ASAP!!!
Old Oct 6, 2004 | 09:33 PM
krazywhitboy's Avatar
krazywhitboy
Banned
Default Need Help ASAP!!!
i just did the mpfi swap on my 89 crx dx. i double checked all my wiring and everything is right. when i try to start the car, gas sprays out off all the injectors! i'm hoping its just the o-rings on the injectors, but its spraying from the top of the injectors where it meets up with the fuel rail. any help would be appreciated!!!
Old Oct 7, 2004 | 03:07 PM
krazywhitboy
Banned
ok well thanks for the help nobody....i replaced the o-rings and that fixed it, but now i'm having another problem. it will start and idle fine, but when i give it gas and let off, it will sputter and die...any thoughts?
Old Oct 7, 2004 | 03:31 PM
v8guy's Avatar
v8guy
Professor
Did you replace both O-rings on the injectors? If the top ones that seal fuel were leaking perhaps the bottom ones that seal air are leaking and you have a vacuum leak. Or perhaps there is a vacuum leak elsewhere. I'd check that out. Good Luck.
