So it appears my PCV valve grommet is leaking some oil (and potentially causing erratic idle when the outside temperature is hot). I am going to replace it but would like to know if I need to put anything on the grommet other than a dab of oil to ensure a good seal. I read on one web site somewhere where the mentioned using some sort of silicone seal.(???)
It turns out that the particular PCV system doesn't add much to the entire vacuum system. I removed the hose into the intake manifold and it didn't do much.
