dx 2 si manifold swap?
Old Oct 17, 2004 | 08:43 PM
mdcrx89's Avatar
mdcrx89
under construction!!!
Default dx 2 si manifold swap?
can a dx manifold be swapped into a dx??????? and is it hard???
Old Oct 17, 2004 | 09:34 PM
augy's Avatar
augy
DX to DX swap? Shouldn't be hard at all.... :chuckles:
Old Oct 17, 2004 | 11:11 PM
mdcrx89's Avatar
mdcrx89
i ment an DX 2 an Si...............my bad.......lol
Old Oct 17, 2004 | 11:59 PM
Kai's Avatar
Kai
Rotorphile.
Intake or exhaust?
Old Oct 18, 2004 | 12:59 PM
mdcrx89's Avatar
mdcrx89
intake manifold, tha exhaust manifolds are the same
Old Oct 18, 2004 | 01:13 PM
Kai's Avatar
Kai
Rotorphile.
Sure, it just takes some wiring, a new ECU, and the complete Si manifold with injectors, fuel rail, TB and all.
Old Oct 18, 2004 | 07:53 PM
mdcrx89's Avatar
mdcrx89
wat all is different w/ tha wiring cuz i have a crx Si im taking it off of, so i have perty much everything i need
Old Oct 18, 2004 | 08:00 PM
Kai's Avatar
Kai
Rotorphile.
Here's a basic DX to ZC MPFI conversion process.
http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
Old Oct 19, 2004 | 07:06 PM
mdcrx89's Avatar
mdcrx89
sounds quite complicated but i will have 2 jus see wat i can do with it, thx man for all tha info :cheers:
Old Oct 21, 2004 | 05:10 PM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
basically u need an ecu a dizzy the manifold fuel rail injecors and the resistor box, there are 4 wires that goe to the resisotor box, they go to the 4 top pins on the top connector of the A plug on the ecu, and 2 wires that go to the dizzy and u basically depin and repin and u may mix up a peach and white wire i did, theres basicly 6 wires you need to have and extend the tps wire. i did this swap on my car when i did the tranny swap now my d15b2 is on steroids.
