How can I be sure...
How can I be sure that the crank is TDC? I don't have that plastic timing belt cover with the pointers on it, and every manual I've read just says to check the crank against that freakin' cover. I can eyeball the little white groove, but that's hardly precise.
By the way, it's a DOHC 1.6L ZC.
Originally Posted by Kai
Pop the #1 spark plug and look down the hole.
I just kept my ratchet on the crank and lined up the ratchet with the white mark. Car hasn't blown up yet....
or take out the #1 or 4 spark plug and stick a piece of wood or something to rest on the piston and stick above the valve cover and turn the crank by hand with a socket and watch the wood or whatever your using and wait till it hits as high up as it can go.. you have TDC..
