tranny swap done. motor wont crank? i need help
Old Oct 24, 2004 | 04:20 PM
Mackenzie C's Avatar
Mackenzie C
Default tranny swap done. motor wont crank? i need help
i got everything back on, axels, hubs, calipers, starter, etc...
i think i got all the wiring back on dont know, that might be my problem. but i turn the key and it doesnt crank. could it be a starter connection problem. the starter is new so cant be the starter itself. ill check the connections tomorrow. other then that, why wouldnt it crank?
Old Oct 24, 2004 | 04:37 PM
ED9man's Avatar
ED9man
driver
transmission ground?
Old Oct 24, 2004 | 04:39 PM
Mackenzie C
wtf is that? is that the thing on the clutch cable?
Old Oct 24, 2004 | 06:29 PM
ManoloCRX's Avatar
ManoloCRX
All Motor
Yep, the negative cable from the batery.
Old Oct 24, 2004 | 06:51 PM
Mackenzie C
hmmmmm. so its connected to the clutch thing to the negative end of the battery? i think ima have to check that out tomorrow. so that connection will stop the engine from cranking. thats crazy
Old Oct 30, 2004 | 05:00 PM
h22afreak's Avatar
h22afreak
IN BOOST WE TRUST.
Starter signal+
Old Oct 30, 2004 | 06:05 PM
teg92's Avatar
teg92
WHAT OK YEAH!
the transmission ground is just a thick piece of wire that goes on top of your tranny and goes to anywhere on the frame, Its just like the ground wire you have near your valve cover
Old Oct 30, 2004 | 07:39 PM
Mackenzie C
i tighted all the grounds and it starts now, it was the ground from the clutch cable to the negative.
