Is it nessesary to remove the valve cover before changing a timing belt? THe book I have doesn't say it is, but looking at the engine makes it looks like it is.
Just changed the timing belt on my 88 CRX SI. It wasn't too bad. I do have a question though... the engine is emitting a high pitched (but not that loud) sound. It's like the timing belt might be too tight.(???) I checked the A/C and alternator belts and they are tensioned fine.
speaking of which, is that an item that should usually be changed when doing a timing belt job?
The tensioner? Some people swear by it, but otherwise, no it's not really changed with a timing belt job even though it should be. I haven't had any problems yet after I did mine.
