slipping clutch
I recently completed a B16A2 swap in my '91 CRX Si. The engine runs great and the electronics are fine, the only problem is my clutch slips... I bought the HASport hydro->cable conversion and it seems like the problem is the converter; it just doesn’t have enough throw... When the clutch pedal is all the way down there is just enough release to allow me to put it in gear, and when the clutch is released all the way it slips a little. If i adjust it one way I cant put it in gear, if i adjust it the other it slips even more. The pressure plate and flywheel are both new so this shouldn't be happening. Is there a way to adjust the amount of throw on the clutch cable or even convert the car from cable to hydro? The slipping clutch isn’t letting me get the real power from the engine and I don’t want to have to replace it every 5,000 miles because of the slipping.
Any help would be great.
btw here's the car
more pictures at www.cardomain.com/id/applesausesi
btw here's the car
there should be quite a bit of adjustment on the clutch cable where the cable goes to the tranny. that's the only adjustment i know of. I had to modify my stock cable on my ls swap to give it more adjustment, i just cut away part of the housing and moved the threaded part up to give me more. Hope that helps any.
thats the part i have adjusted. if i move it one way the clutch slips more, and if i move it the other way i cant get it in gear... its in the "best" location so i can put it in gear, but the clutch still slips a little. I am still using the cars clutch cable, i have heard of people swaping it with the '93 integra cable, is this necessary?
