Intake manifold whistle
Old Aug 24, 2004 | 03:08 PM
89crxinprogress's Avatar
89crxinprogress
Default Intake manifold whistle
does anyone know what would make and intake manifold whistle. i recently swapped an 92-93 civic vx manifold to a 90-91 crx si manifold. everything seems to be secure. however and a certain pedal pressure it makes an annoying whistle. does anyone know what might make it do that?
Old Aug 24, 2004 | 03:59 PM
Kai's Avatar
Kai
Rotorphile.
Did you use new gaskets and make sure all the vacuum nipples where used of capped? It may be a vacuum leak.
(Edit: I said "manifolds" instead of "gaskets." Duh moment, sorry.)
Old Aug 25, 2004 | 12:11 PM
89crxinprogress
thanks i will check that
Old Aug 25, 2004 | 06:51 PM
Kai's Avatar
Kai
Rotorphile.
(I editted my previous post, bump so you'll notice it.)
Old Aug 26, 2004 | 06:36 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Its the manni itself. All CRX Si's do it(if its got an intake). If you want to get rid of the noise youll have to swap the manni.
Old Aug 26, 2004 | 11:00 AM
89crxinprogress
my friends si doesn't. this is a high pitch whistle and it is only when i am giving it a certain amount of gas. i could be wrong but i don't think my friend's whistles i will check
Old Aug 30, 2004 | 06:58 PM
Skunk2CRX's Avatar
Skunk2CRX
BlackMagic
I have the same whistle with my 90 Si...my buddy said if i got a Throttle Body spacer it wouldn't whistle anymore
Old Aug 30, 2004 | 11:43 PM
Kai's Avatar
Kai
Rotorphile.
If it is still running fine, don't deal with stuff like that. Even if it's running poorly... don't deal with stuff like that.
Old Aug 31, 2004 | 11:26 AM
89crxinprogress
Default sorry cant type apparantly
kai...... all of my vacume hoses seem to be fine and i can not locate any cracks or gaps in my manifold. is it possible the whistle is coming from my vacumes sucking to much or to little air? any suggestions.
Old Aug 31, 2004 | 11:55 AM
Benskins's Avatar
Benskins
98 Civic 4dr
mine whistles too, with my intke on it, with like 50% gas at around 3200 rpms.
