CRX wiring help b16a
Old 10-30-2004, 04:43 PM
h22afreak
IN BOOST WE TRUST.
h22afreak's Avatar
Default CRX wiring help b16a
I need some help with this one please,we recently purchased a
JDM 0bd0 b16a motor to swap into a 91 crx si i did my reserch on patrs
needed for the swap but there are two things that are puzzling me ,first
the wiring and secondly the axles can you guys please break the wiring down
for me meaning which wires have to be changed or added can i use the existing
crx si harness or the one tht came with the b16a motor and is there a web site where i can find the PWO ecu pinouts,please guys help me with this one any info will be highly appreciated.
Old 10-30-2004, 06:33 PM
ED9man
driver
ED9man's Avatar
take the entire D16A6 wiring harness and put it on the B16a, then get the hasport wiring subharness to make it easy and clean to wire the extra stuff.
Old 10-31-2004, 12:23 AM
h22afreak
IN BOOST WE TRUST.
h22afreak's Avatar
Thank you ED9man ,what axles are you using?
I know hasport makes axles for that swap but is there another alternative ?
Old 10-31-2004, 07:03 AM
h22afreak
IN BOOST WE TRUST.
h22afreak's Avatar
someone,anyone please help.
Old 10-31-2004, 12:39 PM
jpdrag-on
jpdrag-on's Avatar
Hey go to www.raxles.com I bought my axels from the they were like $320.00
they have warranty, you have to tell them what swap are you doing.
I have them for about a year and they are really good.
Old 10-31-2004, 03:29 PM
h22afreak
IN BOOST WE TRUST.
h22afreak's Avatar
Thanks alot,those axles are way cheaper than the
hasport units.
Old 10-31-2004, 03:33 PM
Kai
Rotorphile.
Kai's Avatar
Used/reman'ed 90-93 Integra units would be the cheapest. (manual intermediate shaft and axles.)
Old 10-31-2004, 03:36 PM
ManoloCRX
All Motor
ManoloCRX's Avatar
The wiring is the same, just add, vtec pressure, vtec, knock sensor cables.
I use the 90-93 integra axles, fit perfect, only you have to remove the rubber ring,
I can't find word to explain in english, but if you have question, I'll try to explain better.
Old 10-31-2004, 03:41 PM
ManoloCRX
All Motor
ManoloCRX's Avatar
Agree, I pay $160,with lifetime guaranty
Old 10-31-2004, 04:12 PM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by ManoloCRX
I use the 90-93 integra axles, fit perfect, only you have to remove the rubber ring, I can't find word to explain in english
It's the outer dustboot.
