whats obd/1/2? what is that stuff?
Old 10-18-2004, 05:34 PM
Mackenzie C
Mackenzie C's Avatar
Default whats obd/1/2? what is that stuff?
total newbie questions, he heee. whats it for? what does it do? what does my car have (91 std civic hatchback)? how do you change it for a swap?
Old 10-18-2004, 08:22 PM
Kai
Rotorphile.
Kai's Avatar
It is the level of complication of the onboard electronics. Each has different plugs on the ECU, injectors, and distributor to avoid mismatches.
Pre-OBD: everything '87 and before. They don't care a whole lot about what you do, and don't trip codes often unless something is completely gone... in which case it still doesn't care much.
OBD-0: 88-91 Honda cars. It gets a little more busy, but is still really simple. High impedance injectors. Cream plugs.
OBD-1: 92-95 Honda cars. This is where it starts getting annoying, more codes are added and it gets a little more bitchy about certain things. It is the last of the one 02 sensor systems (except for the DOHC VTEC engines, which always had two.) Low impedance injectors. Grey plugs.
OBD2/2a: 96+. They are the devil. Stay far away from them.
Your car is an OBD-0.
Old 10-18-2004, 11:09 PM
augy
augy's Avatar
Yeah, fixin' up old cars isn't going to be anything like it is now in about 15 years.
Old 10-19-2004, 08:16 AM
Kai
Rotorphile.
Kai's Avatar
That's what they said 15 years ago. My father won't come anywhere near a fuel injected engine. :chuckles:
Old 10-19-2004, 12:16 PM
Pete
Civilian
Pete's Avatar
I have an OBD 2 engine, with an OBD 1 setup, in an OBD 0 chassis :chuckles:
Old 10-19-2004, 04:53 PM
Mackenzie C
so if you swap a obd 2 motor i have to run that in my car?
Old 10-19-2004, 05:48 PM
Kai
Rotorphile.
Kai's Avatar
That's the stupid hard way to do it. The normal way to do it is to backdate the engine to OBD-0. You generally stick with the system of the body, not the engine.
Old 10-19-2004, 08:26 PM
Mackenzie C
hmmmm, how do you do that?
Old 10-19-2004, 08:33 PM
Kai
Rotorphile.
Kai's Avatar
Reusing your stock harness and swapping in OBD-0 injectors and distributor. Other slight tweaks may come up, it's as easy as swapping plugs.
Old 10-20-2004, 04:10 PM
Mackenzie C
what about the ecu and all that?
