crx engine question
Old Sep 16, 2004 | 06:33 PM
MINIRACER51's Avatar
MINIRACER51
Stubby
Default crx engine question
I just bought a 90 crx hs, how do i tell which engine is in it. the people i bought it from have no idea and i cant find an id tag anywhere, only paid 100.00 for the car and it runs fairly well, any help would be appreciated.
Old Sep 16, 2004 | 06:49 PM
Skunk2CRX's Avatar
Skunk2CRX
BlackMagic
Default if you have the HF...
If you have the HF modle you have a 1.5 liter engine but if you are looking at the motor to the left of the oil dip stick slightly theres a plate facing you as you look at it...should have the engine type right there...its probably really dirty so your gonna need something to clean it up to read
Old Sep 16, 2004 | 06:52 PM
MINIRACER51
Stubby
yea its an hf, sorry thought it said hs, is the 1.5 a pretty good motor????? it has like 172000 on it, doesnt smoke but it has some valve rattle.
Old Sep 16, 2004 | 07:33 PM
augy's Avatar
augy
In short, no, no it is not a good motor, if by good you mean powerful. The HFs get rediculous gas mileage--43/49 for your year. The stock D15B6 is SOHC 8-valve and gets something like 62 horsepower. Obviously, it's a commuter car. However, HFs are sometimes preferred for swaps 'cause of their weight--they lack several of the ammenities that the DX and Si versions of the rexes have, and they weigh a couple hundred pounds less as a result. You can probably find a replacement engine for a hundred bucks, put it in yourself, and you've got an ideal daily driver.
Or you could tear it out, throw in a B series, some fi and have some real fun >=]
Old Sep 16, 2004 | 08:02 PM
MINIRACER51
Stubby
What is a b series engine???? sorry i sound so stupid but I havent messed with foerign cars to much. except for my accord dirt track car, and how much would a b series engine cost aprox??? and what is envolved in the swap. Thanks
Old Sep 16, 2004 | 09:29 PM
91_CiViC_RiDeR's Avatar
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Well for some insight on the B series engine go here and it will give you some knowledge on it http://web.tickle.com/tests/uiq/inde...=banemedia1&z=
It depends on what kind of b series engine you wanna get and how much are you really wanting to spend...They can range anywhere from $650 on up $2,000 if not more.
Now about the engine swap I am no one to tell you about that but I am pretty sure Kai or JaJe or one of the others would be able to give you some info on that!!
Hoped I helped!!!
Old Sep 16, 2004 | 09:33 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Linnked did not work sorry but here is the info
Honda first stunned the world with the introduction of B16A in 1989. A mass-produced normally aspirated engine that hit the magic 100 hp/liter - 160 hp out of 1.6 liter of displacement. B16A has been the benchmark of 1.6 liter engines since then. As of today, you can pretty much classify B16A into four distinctive era. I am going to call them B16A G1, B16A G2, B16A G3, and B16B 98 SpecR.
B16A G1 - The original motor introduced in JDM 1989 Civic/CRX (EF body) and JDM 1989 Integra (DA body)
B16A G2 - From JDM 1992-1995 Civic (EG body)
B16A G3 - From JDM 1996+ Civic (EK body)
B16B - From the JDM 1997+ Civic Type-R
B16A's close DOHC VTEC sibling
B17A
B18C
B18C 96 spec.R
B18C 98 spec.R
Engine JDM B16A G1 (USA B16A3) JDM B16A G2 JDM B16A G3 JDM B16B 98 spec.R USA B17A USA B18C USA B18C spec.R JDM B18C 96 spec.R
Type Water-cooled 4 stroke Same Same Same Same Same Same Same
Cylinder Arrangement Inline 4 cylinder, transverse Same Same Same Same Same Same Same
Block Height ** 263 mm (10.354") Same Same Same Same?! 270 mm (10.630") Same Same
Bore x Stroke 81.0 x 77.4 mm (3.19 x 3.05 in) Same Same Same 81.0 x 81.4 mm (3.19 x 3.20 in) 81.0 x 87.2 mm (3.19 x 3.43 in) Same Same
Displacement 1595 cc (97.3 cid) Same Same Same 1678 cc (102.4 cid) 1797 cc (109.6 cid) Same Same
Compression Ratio 10.2 10.4 10.4 10.8 9.7 10.0 10.6 11.1
Valve Train Belt driven, DOHC w/VTEC, 16 valves Same Same Same Same Same Same Same
Maxinum Output 160 ps @ 7600 rpm 170 ps @ 7800 rpm 170 ps @ 7800 rpm 185 ps @ 8200 rpm 160 hp @ 7600 rpm 170 hp @ 7600 rpm 195 hp @ 8000 rpm 200 ps @ 8000 rpm
Maxinum Torque 111 lbs-ft @ 7000 rpm
(15.5 kgm @ 7000) 16.0 kgm @ 7300 rpm 16.0 @ 7300 rpm 16.3 kgm @ 7500 rpm 117 lbs-ft @ 7000 rpm 128 lbs-ft @ 6200 rpm 130 lbs-ft @ 7500 rpm 18.5 kgm @ 7500 rpm
Specific Output (output/liter) 100 ps/liter 106.3 ps/liter 106.3 ps/liter 115.6 ps/liter 94.1 hp/liter 94.4 hp/liter 108.3 hp/liter 111.1 ps/liter
Intake/Exhaust Valve Size 33.0 mm/28 mm Same Same Same Same Same Same Same
Intake opening (BTDC) 10 15 15 18 10 10 15 15
Intake closing (ABDC) 40 45 45 45 40 40 45 45
Intake duration 230 240 240 243 230 230 240 240
Exhaust opening (BBDC) 40 40 40 45 40 40 45 45
Exhaust closing (ATDC) 7 7 7 10 7 7 10 10
Exhaust duration 227 227 227 235 227 227 235 235
Overlap 17 22 22 28 17 17 25 25
Intake valve lift (mm) 10.6 (.417") 10.7 (.421") 10.7 (.421") 11.5 (.453") 10.6 (.417") 10.6 (.417") 11.5 (.453") 11.5 (.453")
Exhaust valve lift (mm) 9.4 (.370") 9.4 (.370") 9.4 (.370") 10.5 (.413") 9.4 (.370") 9.4 (.370") 10.5 (.413") 10.5 (.413")
Intake/Exhaust Valve Springs Dual/Single Dual/Single Dual/Single Dual/Dual Dual/Single Dual/Single Dual/Dual Dual/Dual
* All cam timing figures are the high rpm lobe. All figures from Honda, which are based on 1 mm (.0394") lift at valve
** Block height measured with steel ruler from deck to bottom of oil pan rail. - Louis DeVirgilio
*** It seems that the above engines do not all have the same rocker arm ratio! That means the same cam will have different lift at valve depending on which rocker arm is used.
People always ask if parts are interchangeable between the above motors. The answer is yes on most parts (valves, valve springs, cams, rocker arm, crank, head). There are only few exceptions like all intake manifolds are interchangeable except B18C. The tranny's for the above motors will also bolt up to each other. But newer ones are hydralically operated while the older ones are cable.
Old Sep 17, 2004 | 02:50 AM
Kai's Avatar
Kai
Rotorphile.
It's worth it's own weight... in scrap aluminum. In other words, it's trash with virtually no good use besides propelling a super commuto-box car.
It's a newer, better series of engine, most of which can be swapped in with various degrees of difficulty. Do a search.
Old Sep 17, 2004 | 07:52 PM
ED9man's Avatar
ED9man
driver
I want to see someone fire a massive shot of nitrous through an HF motor wth some ghetto rigged fuel compensator just to see how long it lasts. :chuckles:
200whp y0! h:
Old Sep 18, 2004 | 08:17 PM
v8guy's Avatar
v8guy
Professor
Its a great motor if you care about fuel economy, which you should these days. Leave it the hell alone and just drive it. Mechanically it is a good reliable engine. If the car is just a toy for you, go ahead and drop in a B series or whatever. Otherwise I say drive it and love that little fuel miser engine.
