- Need some help
- want quick accel
- exhaust shaking
- B18c in a 92 Si
- Swapping headgaskets is fun...NOT
- too many choices, btm's
- Major projects - feasable?
- no power
- what do you think of this tranny setup?
- plug and play harneses" are ther any
- what kind of probelms have peole ran in to whiel installing h22's in a 5th gen accord
- timing
- 88 civic with b16a, What Knuckles do I Use??
- Need Help W/ Nitrous ASAP
- Why isn't my power steering working??
- oil pump
- Is the 96-99 Intake Manifold Throttle Body, and Injectors better than a 92-95?
- what timing you people often talking about ? ? ?
- Help please with friends 97 Accord LX & aftermarket ignition system
- How flat does the Deck hafta be?
- Curing fuel starvation?
- Idle Problem, someone please help
- Tuning
- Nearly every Honda USDM, JDM and EDM engine code
- stock parts balanced?
- Turbocharging a 2G Teg, new motor or rebuild?
- Throttle Body Gasket????
- need help...please
- 81mm or 84 mm b16a?
- Code Identity HELP
- CTR or ITR pistons in ls block?
- 91 civic transmission question
- Skunk2 manifold inlet size?
- 11.5:1 Daily Driver?
- What is everything I need?
- type r pistons
- Water Injection systems...
- Where to Buy Engines?
- distributor internals? b18c/b18b
- All you hybrids..
- need help w/ cel codes
- Wheel bearing cap stuck on spindle, help?
- Would a Zex Cam for 96-00 EX give good results?
- where can i learn about air/fuel ratio?
- whats a girdle?
- Gasoline Direct Injection kit for B series motor ? ? ?
- Help me identify this turbo?
- b16a2 with gs-r harness ?
- 1990 civic si burning oil when revved to 5000rpm...
- civic si = power problem
- what parts of the b18c5 give it more power than the b18c1?
- LS/Vtec - Pass Smog???
- anyone heard of www.hcpengineering.com
- aftermarket rod/main bearings?
- question about oil pan baffle
- injector question?
- help me !!!!!!!!!!
- Spark plugs dont spark on my LS..?
- b16 vtec head
- Cable or Hydraulic
- Integ alternator
- SUMMITOMO tires????
- Need Advice on drivetrain problem for gsr
- check enging light....distributor??
- ignition timing advance question
- Greddy exhaust ID
- Need some help with the P.O.S. ????
- anyone using aem ems and your opinion?
- 99 power steering pump in 93 ?
- Jrsc ?
- How I made a turbo adapter plate
- The engine racket again
- APEXi VAFC..worth it?
- LS into 92si.... no air conditioning?
- B20z
- turbo question
- ECU fuse
- need specifics on 87 Si engine into 87 DX CRX
- install a short shifter
- SOHC Head Gasket Help
- 6 Speed trany??????
- Seats. Any suggestions?
- JDM GSR dynoed.... with zex
- 96-00 civic h/b w/ LS??
- where can i get info on ls/vtec mod?
- h22 or h23?
- Identifying trannies...
- Fmax Kit Instructions Please?
- tech questions...fundamentals of running open head?
- NEED HELP!!! Tranny (LSD) Question???
- what exactly is tuning
- swap a civic radiator into my gsr, or not?
- Andy
- Vtec not working, missing dowel?
- Dash Prob
- Additional needed parts for a N20 set up
- ? about a trade
- All SOHC motor!
- Anyone remeber me?
- type r, h22a or b20 engine in gsr
- D16Y8 head on a D16Y7...
- Quick question
- intake diameter sizing?
- Need information on best setup for Nitrous on a 93 SOHC VTEC
- B18C1 Swap finally in - PICS
- b20 with GSR head
- shopping for a turbo for my b18b?
- 97 Accord VTEC Sudden Oil Spill
- brake master cylinder rebuild or replace?
- Opinions on an F-Max Kit
- H22A in a 6th gen hatch...NEED PICS OF MOUNTS!!
- Injector Flow please help!!!
- Honing with a power drill?
- bushings
- type s piston hi-temp coating and cryo treating
- Bought another CX...now I have twins.
- tranny swap...how hard is it
- Where to buy QUALITY motors?
- Need to find Valve lash # for 99 Prelude
- Handling in H22a 5g Civic coupe?
- h22a Mounts question:which is best?
- tranny rebuild questions...book isn't real specific
- check engine light
- K24 = k20 head
- Compression test #'s to CR?
- no power to spark plugs?
- frankenstein rpm limiting
- does anyone have an LS vtec - turbo?
- Fluidyne Radiator... experiences?
- Increase the RPM while shifting for Auto.
- Valve specs for CTR cams?
- LS/Vtec Cams
- 91 Integra LS VTEC swap info?
- Will this work? Please help!
- why wont my teg start?
- firing order of a b18b?
- 5 angle valve job?
- want to build allmotor beast
- b16 pistons into gsr?
- limits of NA tuning for this setup
- Aftermarket Fuel Pressure Regulator Questions??
- type r motor in crx???
- Please Help.
- installing the V-AFC
- Good price or rip off?(D16Y8 head)
- I hurt my transmission :(
- Import parts for sale at Air Flow Design soon.
- Coolant level and idle?
- Compression and valve clearence ?'s
- Tech articles??
- What do you think the problem is?
- D15A7 Engine
- free F23 block
- Engine Hiccup
- H22 in an Accord?
- ? about CR
- rev limiter..
- Pics of my hybrid.
- Brake booster hose size?
- big problem
- Honda's biggest engine?
- Fast&Furious!What is granny shifting?
- My Car is Pissing.
- N/A gsr
- i stripped the thread on my block where you screw the sparkplug in...
- 94 b18b swap into a 94 civic ex question..
- B18a1 swap
- How many here are blown
- what does a stock B16A2 flywheel weigh?
- White Smoke
- Got my engine
- Omg Intake Manifold Die Die Dieee!!!
- need advice on EXTREMELY soft hydro clutch pedal action
- cam question
- no name intakes on ebay
- Im Installing A Coil Over System on my Integra Rs Help!!!!
- D16Y8 head with CRX Si Block
- civic lx
- Help! Hybrid is giving me problems!
- carb legal cams
- Adjustable Sprocket Help
- What would be more beneficial?
- Obd?!?!?
- gears grind when shifting to 5th on high RPM
- Finding Coolant Leaks...any tried the blacklight dye?
- 5G wiring issue
- What is Blueprinting/Balancing ? ? ?
- Does oil level affect compression?
- Crank pulley
- proper exhaust size for STS autocross car
- 90 Integra GS won't start + s3 light
- in the 11,s with h22a civic
- How I got screwed over by this punkass kid selling a 92 CX
- **HELP! Tranny Question about b16A1 in CRX
- civic detonation
- Car won't start...need some help.
- Compression Numbers
- Compression Test
- simple tire question...
- Stage 3 Power figures
- I think i have a great idea??
- alternator
- 88 Acura Integra Stalling
- I'm sure it's been asked
- My project hatch and his new friend!
- I need bigger axles any suggestions?
- B16 Ecu Question!!??
- Sqeaky Clutch?
- Itr Pistons In 94 Ls
- Suggest a good shift point for me, plz
- Greddy turbo running lean!!! Any Suggestions?
- cylinder boring to 81.5mm ????? How much
- Maybe running rich and how to fix???
- Need Help.Skunk2 cams which to get????
- Little Help
- tranny acting weird...
- Shifting prob
- LSVTEC or Poormans ITR?
- Post your setups!
- JUN, Skunk 2, Toda knowledge..................
- Swaping The 90dx
- Rear Brake Conversion
- Cam Timing
- Fuel Gauge In Instrument Cluster
- Problem with AC/Heater Blower Fan
- 88 integra engine swap question
- How bad is my LS tranny?
- H22 with JRSC in a 5g civic hatch
- head question
- I wanna buy a New engine
- Need help about using ECU P72 with a B16A2 swap?
- ECU question
- Pulling tranny
- 92-95 si tranny into a 00dx
- Boost question?
- CRV Info
- clutch sticking?
- D16Z6 into 4th Gen, Si ecu?
- wire harness differences?
- engine bogging when warmed up? not passing smog either :(
- Heat wraps for Headers opinion ?
- H23A1 Cams?
- S2000 engine on 93 Civic?
- What brand sleeves and block guard?
- oil on my spark plug? OMG!
- El Guage Panel Instructions for 94 Integra GSR
- anyone who works at a dealer?
- vtec computer
