- dry sump and regular oil system
- Info on gas mileage
- swap info needed
- swap info needed
- Pistons?
- IAB wiring?
- GSR Swap
- V-afc settings ? Please help
- radiator leak???
- axles for h22 in civic
- JDM Swaps and Emissions testing
- Mini Me TUrbo?
- valve body screw
- Anyone tried this cheap engine mod?
- OBD conversion
- I'm new..I drive a 00 civic si
- problem with 5th gear on 00 si
- anyone know the size of the f22b2 throttle body?
- best spark plugs?
- Is this valve engine damage?
- Mini-Me swap questions!!! HELP
- Nopi at MIR
- 92 accord probs....
- Problems With 1992 GSR Gauge Cluster.
- ls/ v tec?
- Swapping an LS into a 6th gen Civic EX?
- no-tec to VTEC? newbie question
- 4.2.1 or 4.1 Headers for 97 Ls Integra
- Question on exhaust for 03 Civic EX
- New Exhuast Suggestions
- b16 engine question
- Fun with Clutches
- Urethane bushings install report (long)
- Theoretical question
- pinging issues
- JDM D15b SOHC VTEC specs ??? need help ASAP!!
- which Catback system for 97 integra?
- which wire goes where? help meh...
- some sort of sensor? help me wire this thing
- Starting problems
- Will 97+ teg brake master cyl work in a 94 teg?
- What are typical E.T.s for a '92-95 H22 Civic?
- broken axle?
- temperature high
- An extension (revision) of the SeaFoam injector cleaner post
- Vortec Supercharger
- 2000 Civic EX harness on 2000 B16a2 and/or B18c1 motor???
- my timing is screwed
- proper prodedure for clearing DTC's from ECU memory
- getting B18C1..........
- Squealing belt?
- JUN Stage 3 cams vs Skunk2 Stage 2 Cams(+)
- OBD1 motor in an OBD0 car
- tranny question ??
- going very leasn in LS/VTEC - help needed
- going very lean in ls/vtec - help needed
- I know nothing. Honda mower Q??
- d16y8
- Questions on CEL Codes
- cant get distributor off???
- timing belt
- idel rough
- Extension of my crank pulley bolt situation
- o2 sensor problem, brand new but...?
- Brake problems?
- idle problem in LS/VTEC
- Problem with idle in LS/VTEC
- how much boost?
- I Need Tourqe !!
- need emergency help, car threw its crank pulley bolt
- engine rebuild estimate
- starting problem
- Jumping tach needle!!!????
- *PICS* h22 Swap into 6th Gen *PICS*
- turbo si help!!!!!
- ls/vtec
- D16z6 headgasket
- Is a B18C1 slower than a turbo D16
- 6 gen accord h22a swap wiring info help!
- cable/hydraulic clutch?
- Nitrous Express?
- h22 in 97 civic hb
- smoke gray, engine ring leaking?
- ECU is only throwing one code, seems to have many other problems
- dist cap........a lil dif that other one
- LSD tranny for b18b......
- compatable tranny
- transmission ratios
- Car stalls after 2 minute idle..y?
- Code 22, Vtec Oil Pressure Switch Defective
- Installing Clutch ... heh
- Race Fuel Cell hookup-- Help!
- 99 Si.....
- Ls vtec or b16?
- H22 into an EK
- Half way thru my grounding project
- VTEC life?
- general turbo question
- cheap swap
- General Swap Questions
- Carbon Clutch/Flywheel Assembly
- Spraying on highcompression
- timing adjustment??
- direct port n2o install
- help!! limp mode??
- Car grinds on 3rd gear downshift, pops out of 3rd, won't go into 2nd
- service manuals online,,,, now they work
- Injector and Rail question!
- What Ignition Timing for best mpg?
- brake system
- upgrading fuel injectors on turbo LS
- electrical wiring question cooling fan
- Problems: Car shuts off DURING nitrous run!!
- grinding in reverse....
- PLEASE HELP w/ valves
- D16Z6 Head Swap on a D16Y6
- header comparison...
- Tranny question
- JDM B16A2 Swap in 92 cx wiring ?'s
- extension of my valve spring question...useful with new fuel map but stock cam?
- Car Probs
- B18c injector Question
- Car Heats UP Badly
- Water Leak From AC
- O2 sensor wires
- Head bolt question, (exhaust mani bolts)
- Vtec RPM
- how high can D16A6 valve springs rev?
- Ways to firm up brake response?
- Grounding stuff! any stuff to add..
- N2O Help
- LS/vtec or GSR?
- FlyWheel?
- help please
- help please
- Need Help: B16A2 VTEC Wiring
- Timing?
- OBD1/ OBD2 02 sensor locations.
- B16B....How good is it?
- Uberchip
- Injector Question in General!
- CRX Question
- S2000 Engine in a Civic 96-00
- Injector clicking at startup
- Questions on B18c1 swap..
- Toyota tranny question
- H22A swap/immobilizer
- turbo integra advice..PLEASE HELP
- what are these springs on the header for?
- d16z6 Questions
- supercharged...
- Advance/Retard timing question!
- Pulleys - worth it?
- How to install VTEC oil squirters in ls block?
- boost leak???
- tapping into vacuum cleanly
- what all is needed.......
- exhaust manifold bolt torque!!! HELP
- Q About Sleeving
- Cable Clutch HELP!!!
- How 2 Identify JDM Tranny...
- Intermittent Soft/spongy braking?
- D16A head on EW timing belt?
- zc intake manifold capatability??......
- TODA spec B cams - what valvetrain can or should I use?
- tranny question
- 96 2.2 Accord intake, exhaust, and computer mod recommendations
- VERY HOT cockpit!
- D16Z6 All Motor Help
- Crower Stroker kits
- Ecu Code
- What's The Ideal Swap For Reliability?
- How to do a mini me swap?
- engine prob
- 2.2CL vs. 2.3CL
- Gasket replacing question..
- t'time
- V-AFC and rev limiter
- Fraud Warning: Missing Link
- What's the purpose of a cold redline?
- b16 tranny questions
- exaust question...
- h22a question
- Deceleration Probs
- Piston Install: SUCESS
- Need help w/ ecu
- When to replace DIS spark plugs
- idle screwd up
- Rim scrates from lug nut wrench?
- How long does it take you to go 60mph-90mph??? I want to compare...
- Toyo Proxes FZ4
- questions about turboxs boost controller
- h22 accords shift point
- spoon vtec
- High-Flow Fuel Filter other than AEM?
- Tile waste gate?
- lsd effectiveness on 12 second car?
- Engine Shifting
- RS*R exhaust and turbo
- Is this normal??!!
- Replacement for D16y7 header
- What header should i choose?
- 3.2 Legend type 2
- Mount ITR camchafts in a GS-R?
- Engine noise 1988 Legend
- fuel tank pressure sensor
- Need some tech info.
- Is it safe?
- what is the stock fuel line size in a 95 civic?
- water in the oil?
- GSR w/ fuel problem
- S&S Headers..
- Water in the oil?
- 92-95 Civic H22 swap questions
- will EX acccord pipes , cat and muffler fit LX?
- Axels for B16 Swap in CRX
- oil on the spark plugs
- balancer shaft seal
- Best Intake Manifold for Turbo Setups
- problem with b18c1 in 5th gen si.. (no spark)
- Secondaries Problem!!!
- New Timing Belt
- Short Ram Intake?
- Finding Mobil 1 0W20
- Apexi V-AFC
- Burning the clutch? How punishing is this?
- 92 teg RS engine(B18A1) swap
- spark plug gap questions
- It's... Alive! Sorta.
- Sulfur Smell
- cel code 63 (grrrrr)
- 1992 Integra ECU Chipped Problem?!?!
- 92 Acura RS to GS Swap
- Convertable Prelude with 4 WHEEL STEERING
- Which AEM V2 CAI for LS/VTEC 94 teg?
- At salvage yard, what does no 606 mean?
- Compression in LS/VTEC: 11.6:1?
- Ebay?
- Oil squirlters in B Vtec?
- Pistons?
- Engine Stumbling ALOT
- engine rattling?
- Aftermarket Flywheelers Wanted!
- No one can solve THIS problem!
- Port and Polish, who would you choose?
- Cams Replace Crank in new Engine Design
- Fuel Line 101
- Need Another Car
