H22A swap/immobilizer
Old May 26, 2003 | 08:36 PM
SoCalAccord's Avatar
SoCalAccord
Default H22A swap/immobilizer
I want to swap a H22A into a Acura CL, and I was curious about the immobilizer. On the '97 up preludes, they have an immobilizer so if I used one of thoes engines would I need to use the immobilizer too since it is integrated into the ecu? if so, what exactly would I need to do? does the acura cl have an immobilizer? thanks
Old May 27, 2003 | 07:47 PM
v4lu3s's Avatar
v4lu3s
use a jdm ecu or a 1996 ecu to avoid it.
Old May 28, 2003 | 11:20 PM
SoCalAccord
do the JDM motors use OBD 2? or is ODB a US thing only? I would like to try and smog the car eventually, legally. Thanks
Old Jun 6, 2003 | 09:23 PM
v4lu3s's Avatar
v4lu3s
obd2 is obd2 anywhere
Old Jun 12, 2003 | 09:37 AM
XxRONNxX's Avatar
XxRONNxX
MUGEN Whore!!
I'm running a 98 JDM ecu and it is OBD2. Excatly the same as its US counterpart minus the immobilizer. I was even able to pass the state ref 2 years ago and got my BAR sticker. I smogged it last week with the same ecu and it passed...100% legit. You shouldn't have a problem with it.
