- Questions about engines + extra horsepower?
- Broken timing belt 93' 2.3L at 104k
- H22 and INTEGRA does that match?
- Im new and I need help
- What Do I NEED
- starting problem
- Need help w/ VX engine change
- p28 or p30 ecu
- JDM B18C need help
- AIT sensor question
- 92 HB w GSR need exauhst help!!!
- IAB question aka secondary butterfly
- O2 sensor trouble, P1167 code
- How about some tips for better MPG's on the CL's
- How can I get 300-400hp out my integra
- Knock sensor
- HELP - 1988 honda accord lxi will start then it will stumble and die.
- please help
- Skunk2/Uberdata
- Ls/Vtec question?
- zc auto tranny torque convertor not locking up!!!
- 12 mpg on a 2001 MDX - what give
- Weak VTEC???
- h22a engine swap with an integra
- help!
- Help!!! H22 Axles...
- High Performance Cv Axles
- 90 Accord need Engine Info
- Header time, 4-1?
- Bogging? or something?
- question about coil?
- Swapping a b18c into an ls teg
- bogging out
- Cat and Header question
- B16 or Gsr Head ~help~!!!
- b16 or Gsr head?? HELP!!!
- help me out here ppl......
- Shady-Shot Nitrous kits?
- 3 gear grind in gsr
- Is this anyway possible
- Swapping a GSR into an LS
- it wont run rite
- Could This Be The Culprit
- engine problem
- A/C Leaking on the High Side
- Let's talk Mod Chips...
- detonation/pre-ignition... HELP!!!
- Chipping a auto P28 to Manuel
- h22a in a 1st gen tegra
- zc help
- Engine Temp Problem
- re
- Clutch Help Please [H22 swap into Integra]
- what is there out there for Obd0 ecu's
- Looking for crome pro??
- throttle body needs replacing
- b18b turbo+nitrous
- Engine Sounding Like A Diesel When Accelerating
- swapping a b20b/z vs B18b
- RSX tranny in a Civic?
- Timing 1991 honda accord f22a1
- The "Idea Circus" in my head is on parade
- need help turbo wont go into boost
- 89 Civic Motor Help
- need help with my integra automatic to standard conversion
- G2 Integras, Cheap Swaps?
- code PO170
- Damaged resonator? What to do...
- B18A1 swap info about it being in a 95 civic
- Anyone heard of ShadyShot Nitrous kits?
- B16A ignitor.
- Harness ? on swap! HELP!
- vtec works when it wants!!!!!!!!!!!
- 94 b18C into a 98 teg question
- porsche exhaust
- Replacement of Ball Joints
- b16 or b18c
- Turbo IS300 having some problems..
- VTEC problems
- b18c rattle at 3,000????
- 88 CRX Si, d16 convert to vtec???help me please!!!!!
- a few questions... (MAP)
- Breather Hose LS/Vtec
- All Motor K20a2 EG Drag Car Build - 56k, Fly a Kite
- Question about turbos
- h22 want rev past 7200 no vtec
- Planning an engine/tranny swap
- b16, b18 head swap question
- 99 civic si m/c
- help me pick a turbo, etc...
- b18c1 into a '97 civic EX..what 1/4 mile?
- engine swap: B18C into a '97 Civic EX
- Whats the difference
- couple of concernes???
- G-box Performance Mod feedback
- RSX Won't go past 5500 RPM in drive
- vtec for b18a1?
- Check Engine and Maintenence Required Light
- Strut question
- engine swap questions
- H22 Guys
- Turbo Set Up??
- What is the best ECU up grade for a b16a1?
- What is the best way to tune my B16a1?
- want a turboed engine.....?
- Question about header fitment?
- heads
- will my 92 teg tcm work wit a gsr automatic tranny
- Ping/detonation vs. engine timing
- What do ya'll think of this?
- your thoughts on these headers?
- Building your own nitrous kit
- turbo b17a
- Cheap crank pulley removal tool
- compressor maps
- Aight .S2000 eng. with a RSX TypeS...
- Aws Light
- Stock Block Octane Limit
- Smoking engine (please help need to fix asap)
- SRI or CAI on ZEX GSR?
- trouble with a tach
- help!!! clutch pedals keeps sinking to the floor
- help needed to build a motor
- engine sleeves
- newb question: plz help
- TPS Question
- Uberdata/Crome Tuning
- everyone cheer on shmoo for his test!!!
- GSR tranny making noise??? [B18C1 in 96-00 Civic]
- H22 differance
- B16a2 Turbo??
- smoked the ECU
- GSR and oil??? [B18C1 in 96-00 Civic]
- Acura TSX hybrid?
- 99 civic si Timing Belt Installation Help
- manifold pressure relief
- ECU question
- H22 Question
- h22a swap in a 93' accord
- Need help!Valve adjustment '96 2.5TL-Help
- B18C1 vs. B18C5
- fuel pump
- regular to synthetic oil?
- I think I have a blown Head Gasket
- CEL 43 in 94 LS
- Engine set up?
- 1995 Civic DX... Questions on a swap....
- automatic B18A into automatic civic?
- individual throttle bodies?
- so i axed the girl cam i come over? haha! get it?! nevermind...
- TCS light
- B18A1 into 95 Civic
- DUal fuel feed??
- need help please
- k series or ls
- ECU Made my car overheat!!!
- 1990 accord LX fluid checks
- Need Help W/ Exhaust!!!!!!!!!!!!!!!!!!!!!
- Please help--swap problem
- Turbo Build up .. Need help with Fuel Set-up
- Piston ring install
- Boosting My d16z6
- h22a smog legal?
- Best turbo for my application
- Ridiculous compression readings! What'd I do wrong?
- 94 civic h22a
- cheap hp?
- JDM B16 into 99EX coupe Quick Question.
- wiring gurus come at me
- AEM Fuel rail fittings
- DOHC ZC d16A8
- Dart Block Or Sleeves
- Engine swap ITR B18C6 in to Civic B16a2 EK4
- My tranny wont shift! please help
- Ls vtec
- LS rods
- runnin poorly after head swap
- repair manual and wiring diagram
- Tranny Fluids
- b20b....no knock sensor??
- b20 in crx
- 96 OBD2 Ls in 95 OBD1 Civic Ex need ECU
- new engine
- D16Y8 Supercharge vs. K20
- weird clutch problem
- Gearbox Problems
- 91 integra coding 4 blinks
- Engine Swap Questions
- Quick ZC question
- Power Steering removal
- my 00 civic si keeps blowing alt. fuse !?!?!
- free data logger
- Finalizing swap
- 93 civic ex keeps blowing back up fuse
- B16A/B20B questions?
- H22 A/c
- Assistance Please
- b20 vs. ls
- are there pistons and rods for a "grey plug" zc?
- Student In Search Of A Master
- OBD-1 Datalogging question
- Problem with my b16a
- Restore Electrical Power After Accident
- will it work?????????
- h22 in 90 integra?
- h22
- y7 head
- h22 SWAP 94 gsr passenger side axle ????
- Honda/Acura Engine List
- 01 GSR turbo project???
- OBX camshaft is Suck
- question about b18c swap
- Apexi Super S-AFC-2
- turbo block:All motor
- 96 civic to integra motor swap
- Need some help
- idle to high
- hey honda heads i need some help!!!
- need help frankinstiening my engine
- what do you nitrous freaks think of this?
- Dizzy question!!!!!!!!!!!!!!!!!!!!!!
- LS/VTEC pistons
- need help w/ engine swap
- skunk2 intake manifold
- B20Z VTEC. Need to know about valve reliefs: Necessary or Not?
- Need help on removing a crankshaft bolt
- PCV removal on 91 integra
- car hard to shift in first gear
- Vtec Solenoid
- Hondata S100,s200,s300?
- 99-01 si rear tanny mount
- Compression
- South Africa Fmu (go-tech)
- odd overheating issues
- What Engine Do I Have!?
- Prelude CLUTCH Line Problems...!!! Please Read.
- Block Gaurds "Do or Dont"
- B20VTEC install!
- Clanky Klunk Noise
- Help! Turbo Oil feed line
- turbo help please!!!!!!!!!!!
- Question
- Fx How To Make Work A/c Air Conditioner In A H22 Swap
- d15b2 with y8 head distributor problems HELP!
- b18a1 into a 91 crx dx
- How does this set up sound?
- D16A1 Turbo question
- Accidently Ripped Hose
- New fuel pressure regulator design: Opinions Please
- using nos with rpms
