ECU Made my car overheat!!!
Old Aug 10, 2005 | 11:23 AM
imnot4n's Avatar
imnot4n
Dangerously Advanced
Default ECU Made my car overheat!!!
I've also posted this same problem in the civic/del sol/el forum.
https://www.honda-acura.net/forums/s...d.php?t=199815
Ok, so heres the rundown.
-1992 Honda Civic DX sedan w/ D16Z6 swap
-Been running p06 ecu on engine since November(lack of knoweledge of car vtec)
-Recently purchased ecu off of ebay---> http://cgi.ebay.com/ebaymotors/ws/eB...3AAAQ%3AUS%3A1
-Plugged up p28, check engine light pops up (uh oh)
-Drive on the p28 for about 20-25 mins
-Before exiting car, I notice heat meter is on the H!!!
-Plug p06 back up, car runs fine(no vtec) but no overheating problems
-CEL check reads code 21 (vtec spool solenoid valve) [attached thumbnails]
-Need plug for solenoid, and wire to ecu for working vtec
-But the question remains...Why did my car overheat???
Why?
Thumbnails may or may not help.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 11, 2005 | 08:38 AM
mberndt's Avatar
mberndt
Most likely the reason your car overheated, given your particular situation, where it only overheated as soon as u put new ECU in...is prob because of the ECU's fuel curves and more importantly the ignition timing. If u ran P28 on a D16Z6, then it should be ok, but maybe the ignition timing is set incorrectly (distributor), and when u try and use the P28 with VTEC, it changes the timing, for worse, making the engine overheat...
Plus I'm not sure how good it is to run a P06 with a D16Z6 motor... Can't say that damage was done, but I'm unsure...
Did u try and put in P28 again and see if it overheated??
is it ONLY when the P28 is in, that it overheats??
Old Aug 11, 2005 | 10:38 AM
imnot4n's Avatar
imnot4n
Actually I drove home from work the other day with the p06 in and noticed my car overheating. It was about 3/4's the way up and slowly rising and my place of employment is only about 7 minutes away. So I dont know if plugging up the p28 caused something to short out, or whatever, but my car ran fine before I plugged up the p28 for the first time.
If the p28 changes the fuel curve so much, then what should I do to be able to run the p28?
Also, what could be causing my car to overheat after I plugged up the p28?
Old Aug 12, 2005 | 01:11 PM
Paulll's Avatar
Paulll
Hail Bent
www.slowmotionmotorsposrts.com <== columbus shop you might want to check out
You might need to upgrade the radiator. Also, consider how hot is it outside.
