PCV removal on 91 integra
Old Jul 27, 2005 | 08:44 PM
Redblurr's Avatar
Redblurr
Pił Allentato
Default PCV removal on 91 integra
How an i supposse to remove that valve for replacement? I cant get a hold of it? do i remove some parts to get to it or should i just use some chanel locks to get it out?
Old Jul 27, 2005 | 10:30 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is shoved way back there, but a pair of pliers or vice grips will be very helpful if you can't remove it by hand.
Make sure you also pick up some hose to replace what is on there now since it will most likely rip due to age and wear.
Old Jul 28, 2005 | 09:07 AM
Redblurr's Avatar
Redblurr
Pił Allentato
good looking out shmoo. thanks for your help.
Old Jul 28, 2005 | 05:37 PM
Provocateur
On permanent hiatus
No problem.
Did you get it out yet?
Old Jul 29, 2005 | 12:30 AM
Redblurr's Avatar
Redblurr
Pił Allentato
nope, i nearly broke an injector trying to pull it out. the chanel locks could not do the job. and i dont want to brake it either. the sides and part of the top of the valve are scraped off. but i guess i will keep trying.
