- what engine swap should i make?
- how do you make an ls-vtec engine?
- looking for your projects...
- Turbo trim Q's
- racing tranny
- Jdm B20b?
- need to know
- TPS adjustment help needed
- ZC Questions...
- NEED HELP WITH MY CAR! Please read and respond!!
- Jdm D15b????????
- Accord "small light" fuse keeps blowing
- what is this? head w/OUT valves
- converting a 90 accord automatic to stick
- d16y8 into an eg
- finding out if engine is original
- idle vibration....
- vtec oiling components???
- B16 site?
- About my B16A and the bottle?
- C/E Light Problem Found - Map Sensor
- Factory manual
- Cold Air intake ques
- How do you convert you ls/gs motor to vtec
- steering
- Valve qeuchins
- F22 --> H22
- psi on Fuel Pressure Regulator!
- lightweight CRANK pulley???
- Why higher flow is bad for low end power?
- Idle Problems
- We need your vote, official poll
- dash lights on passport
- CEL help
- need shaft help on swap??
- CTR, or ITR pistons?
- In Need of Help With Primary O2 Sensor Wiring
- ignition question
- GSR motor (w/ ls rods and crank), which tranny?
- H22a into a civic ex??
- SOHC Motor problems
- brake help
- Qabout getting block bored and sleeved
- ECU applications?
- ECU applications?
- How do you like this turbo setup
- Timing belt brands
- Q about getting your block bored and sleeved
- oil leak.. need help
- short shifter
- SRS ques
- Theory questions????
- basis question about cams w/ turbo
- why do you lock threads?
- Engine Oil Cooler Leak???
- which built is faster ???
- P28 or p72 ecu?
- engine info
- Anyone hear of a h22/ls hybrid
- manual boost line
- 87 Prelude Si problem
- to mrfatbooty
- problem after finished swap
- The official "come on ferrealb16, drop some mad knowledge on our azzes y0!" thread.
- Help with choosing a cam
- B16A1 swap done, but speedo won't work?
- stock ignition w/ high compression??
- biggest bore size?
- Bench grinding a cam?
- swap plans
- custom turbos
- new electro turbos
- B16 Cap and Rotor
- Gs-r Crank In Ls Block With Itr Pistons
- Bov Install!!??
- My Plans need help before I buy
- need help!!!
- CEL when eliminate cat - What happens?
- H22 Swap.........
- Where to find an engine
- Why am I still slow?
- Fan relays on 90 Legend?
- B16A ass + B16B head???
- Help needed, 91 accord
- vtec switches and solinoids same?
- 91 civic dx won't start
- My 92 Gsr Is Dead!!! *Cries*
- 3rd Gen Accord Engine?
- Screwy Idle and Cold Start
- Cylinder #3 bad compression
- Car died, need help troubleshooting it
- NGK copper spark plugs
- Suspension Upgrade...what do you think?
- Mount Bracket
- How much is the D16A6 worth?
- spoon strut bar for hybrid
- Funny Noise Coming from my b18c
- HELP!! OBD1 pinouts
- h23a pin codes
- cam gear questions
- SRR FD 4.7 vs. 4.9
- header for 97 civic
- still need help with a CEL...
- safe running 12psi, what do i need?
- engin noise at 3000rpm, help!
- good suspension for a 95 Civic w/ B16A
- I taught my hybrid how to wink
- next for turbo ex?
- Need brake help ASAP.
- rebuild tranny? or new one?
- ECU chip?
- Adjustments For Ctr Pistons In Itr Block
- Differences in B16s
- oil leaking
- Problem with B16A???
- h23, h22 qustions
- squeaking noise comming from intake?
- Putting turbo into GSR?
- oil in coolant tank[and floor]
- how hard is it to install a short ram intake
- Thread Size For Oil Pressure Sending Unt
- just a question me and my buddy have
- Jdm B16a, Usdm B16a??????????
- 96 prelude Alternator
- Tube Frame Chassis questions...
- Weird ECU code
- obd2 to obd1
- which headers?
- need help with swap
- what exactly does the cap & rotor do?
- I just got another motor
- building a "stock" lsvtec.. ?
- JDM questions for JDM motor owners who live in cali and have a BAR certification...
- Need Help ASAP!
- Vtec...Good or Bad?
- roughly, cost for B series rebuild?
- Any 4G hatchs with B20 swaps?.
- Heater core question!
- question about the Unorthodox Lightweight Flywheel
- Think this would work?
- Swap Prices
- turbo for swap
- better throttle response?
- SKUNK2 chip questions
- JUN cam gear for SOHC???
- rear drum-> disc swap q's
- radiator fan question!
- ITR flywheel, 3 lbs make a difference?
- h22 in 95 civic hb, good? bad?
- Nos with AEM Fuel Rail
- anyone know the voltage range on the tach wire?
- CEL, Primary Oxygen Sensor - Heater circuit malfunction
- squeeching sound in engine bay
- COLD starting
- HELP! messed idle and high temps
- ecu chipping
- Maint Required
- cut heads?
- Need Help: Radiator Coolant leaking from the back area.
- Obd1, Obd2
- Engine rattle (different from the thread below)
- "building" an engine
- Few D series Q's
- Give me some head ... info
- Need Help Troubleshooting? Engine rattle.
- B16 wiring into 97 EX Need help please!
- BURN IT! Only anwser I found. Can anyone help?
- burning tons of coolant
- 1997 2.2 CL Transmission stuck in 2ND
- Where can I find engine codes and what they come stock in?
- My CTR, what car would it be the easiest to put in?
- H22 from preludes only?
- Got a H23?
- what does *flooding the O-2 sensor* do?
- unorthodox crank pulley/flywheel upgrade?
- Valve job :confused:
- Fuel & Sensor Problem.. Help
- Difficulty Starting Car in Cold
- How can I get it to start smoother?
- crank but no start
- argument on max compression ratio for 91 octane fuel
- New Engine Technology
- Accord Ignition Problem
- Weight questions: motor swap, CF hood, battery
- CEL code 141, need help
- Cams
- b20
- Euro Type R manifold
- Need to get JDM GSR Swap running!! Please Help!!!
- RPM's
- all motor d16y8
- Torque Specifications?
- anyone ever used Marvel Mystery Oil?
- Built f22a4 or used h22a?
- fuel and exhaust systems
- LS/Vetc intake manifold
- turbo timing for gsr
- direct port nos setup
- engine prob
- What spec do I use?
- running rich on my d16z6
- GS-R motor into a ITR motor?
- B18C long block or no long block?
- ??h22??
- what sensor is this [PIC]
- d16y8 head - mini me swap..
- Legend Interior swap?
- Help with rod and piston sizes!!
- turbo 94 integra gsr radiator question
- F20B in a 5th gen Accord
- alternator & power
- Stock B18A1 crank
- shock absorbers
- Shock Absorbers
- B20 buildup
- Anyone Make own Turbo Kit?
- is it worth it to swap in a b16 into a ek hatch?
- GSR intake manifold Install??
- suspension question? >
- 03 Accord V6 rotten egg smell
- For those of you with Prelude swaps in your 5g's.
- Turbo on B17a or B18a What do I need?
- D16z Vtec OR swap? LONG POST........
- Head Gasket Removal
- What else do i need for my swap?
- need HELP ASAP "fuel"
- Type R Rods
- I'm I screwed????
- swap install price?
- need oil and tranny fluid
- teg drinking gas
- JDM and USDM cams
- Running rich...o2 sensor?
- twin turbo on an I4?
- Please suggest shop manual: Odyessy
- Civic AWD??
- Si cluster question
- what's the benefit?
- Good Muffler Shop in NorVa Area
- Blue printed Motor ???
- MSD blaster, worth it?
- Vtec controller questions
- how to raise idle...
- Throttle Body Compatability??
- whats a good FPR?
- adjusting gear ratios...
- Going h23 and have a couple q's
- Help Cel 4
