Factory manual
Yo i need a factory service manual for a 99 ex coupe d16y8 anyone have a link to a pdf or something let me know.
I'm looking for the valve adjustment measure ments i know it's .20 mm but i need the rest of the info.. any links.. anyone?? i dont feel like buying one.
If you want a service manual, go here:
http://helminc.com/
If you just want to know how to do a valve adjustment, follow these directions:
http://www.c-speedracing.com/howto/v...alveadjust.php
That's for a B18C, but the process is the same. You won't need angled feeler guages or a special wrench, though. A box-end 10mm wrench, flathead screwdriver, and normal feeler gauegs work fine.
Valve lash is:
In: 0.18-0.22mm or 0.007-0.009in
Ex: 0.23-0.27mm or 0.009-0.011in
Valve lash should be adjusted cold.
http://helminc.com/
Valve lash is:
