CEL, Primary Oxygen Sensor - Heater circuit malfunction
Old Dec 12, 2002 | 03:04 PM
Grim's Avatar
Grim
Default CEL, Primary Oxygen Sensor - Heater circuit malfunction
My CEL light was on, I checked it and got a CEL code 41, primary oxygen sensor - heater circuit malfunction.
(primary oxygen sensor) & (heater curcuit malfunction)... are the two related or are they each possible problems?
Also, what needs to be done to see exactly whats wrong/ how it can be fixed? Could further driving do any harm?
Im sorry for knowing absolutely nothing, any info would be greatly appreciated.
Old Dec 12, 2002 | 07:02 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Have you done any electrical work lately? I fried my O2's once while I was wiring an A/F ratio gauge. Anyway, I got primary and secondary O2 codes, as well as the heater circuit codes. I replaced both my O2's with universal pieces that were spliced on. The primary O2(EFI Systems) worked very well, and my primary O2 codes went away. The secondary(Bosch), however, didn't work all that great for some reason. All my codes went away, excep for the secondary O2 heater one, and now that I think about it, I probably got the heater circuit wires reversed when I spliced the harness on. I ran like that for about two years with no real problems, so driving like that shouldn't be too bad temporarily. You should try to handle it at your earliest convenience, though, since the primary O2 is very important. My secondary O2 codes went away completely after I swapped in an OEM O2, and after two years of the CEL staring me in the face, I was once again code-free.
Old Dec 14, 2002 | 10:05 AM
jpaik's Avatar
jpaik
yup, if you installed an exhaust recently, you might have pulled the wires out of the o2 sensor or put them in the wrong order.
when i installed my exhaust, the wires got pulled and i put them back in, in the wrong order. i got the same cel 41 code and i just rewired the o2 sensor and then reset the ecu. cel gone
