I just got another motor
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
I just got another motor in my car because blew I the other one so far I got header, intake, and exhaust on it and its a 97 ls non v-tec motor any suggestions on what should I do next I wanna try and go the non turbo way (all motor)
91' Toyota Supra
My goals that are intended are to try and go all motor just because i dont know enough info about the turbo way to do it and i keep hearing turbo is pretty high maintenence but if you guys can teach me about the turbo way maybe i might just do it
91' Toyota Supra
thats what i was thinkin except for the over sized valves what about for the clutch and how far can i go with an all motor (as in moding it) and still have a some what reliable car
I would prefer to have an ALL MOTOR setup, however someone made a good point. Someone here on the boards, I forget who. All motor setups give you full power all the time. You can't just turn down the power like you can with a Turbo setup. For someone like me in Pennsylvania, we see lots of snow and ice, I'd like to be able to have a setup where I could change the amount of power easily, but not have the maint required by having a turbo setup.
So, all motor with all power all the time is good, if that's really what you want. If at any time you would like to be able to cut back that power, may want to consider a turbo setup instead.
