ZC Questions...
Old Jan 11, 2003 | 01:19 AM
seth90dx's Avatar
seth90dx
Default ZC Questions...
Yea, can you put a B16A or B18C1 head on a jap spec ZC motor? The ZC is dohc vtec, so how close are the heads?
Old Jan 11, 2003 | 05:41 AM
p'sH23Acoord's Avatar
p'sH23Acoord
Are you sure the ZC is vtec? I don;t think it is. Why would you want to put a b16A head on a ZC?
Old Jan 11, 2003 | 09:56 AM
dubcac's Avatar
dubcac
I
NO
Old Jan 11, 2003 | 10:40 AM
seth90dx's Avatar
seth90dx
yer right, the zc isnt vtec... Thought it was :dunno: But why couldnt you put a B16A or gsr head on it? They are both dohc, is the bolt patern diff or somn dubb?
Old Jan 11, 2003 | 10:50 AM
seth90dx's Avatar
seth90dx
Also, can you guys give me (to your best knowledge) all the performance parts available for the ZC motor? thanks.
Old Jan 11, 2003 | 10:53 AM
seth90dx's Avatar
seth90dx
Another question, does the ZC mate with any D series trany?
Old Jan 11, 2003 | 12:21 PM
p'sH23Acoord
Yes the ZC does mate with the D-series but you have to switch the clutch. I had a crx with an Si tranny. Rocket! 70 mph in second gear at 7000 rpm.
Old Jan 11, 2003 | 02:26 PM
seth90dx's Avatar
seth90dx
Sounds good to me! Whats up with that clutch? And who makes cams for it?
Old Jan 11, 2003 | 02:43 PM
p'sH23Acoord
The output shaft on the ZC is different then the SOHC output shaft. You need an ZC clutch or Si. As for cams ????
Old Jan 11, 2003 | 04:35 PM
seth90dx's Avatar
seth90dx
So what transmition did you use to hit 70MPH in second? was that the A6 or Y8 trany? I can use an SI clutch? off a B16A or a D16A6? I know they make cams for these cars I met a guy who had them.... Might have been web cams... I think.
I currently have a D16A6 with an act clutch so if its the D16A6 SI you speak of Im stoked!!! ZC + SI trany + act clutch
