oil in coolant tank[and floor]
Old Dec 18, 2002 | 11:52 AM
coco8724's Avatar
coco8724
Default oil in coolant tank[and floor]
lost 2qts oil into coolant and into overflow..Oil looks clean..is 92 Legend 3.2 v6. Engine not overheating. Overheated 5yr ago when plastic radiator top cracked. Dealer licking his chops over a 5grand overhaul[no way] says bearings most likely damaged..Eye said oil looks good and clear, not foamey..is there a place to get the oil checked for coolant in it...any ideas where the problem lies..."just in tyme for christmass"
Old Dec 18, 2002 | 11:54 AM
coco8724's Avatar
coco8724
the clean oil is on the dipstick
Old Dec 18, 2002 | 03:11 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Most like a blown headgasket, especially if it's around the oil port that feeds the top of the head. [where the pressure would be highest]
-Harry
AIM: NDcissive
Old Dec 18, 2002 | 04:44 PM
coco8724's Avatar
coco8724
ty 1stGenCRXer for the thought...was wishing there was an oil cooler somewhere in or on the 92, 3.2L which could spring a leek into the water.
..Q...92 was beginning of in line V-6, and wonder if head gaskets can be replaced w/o removing engine...is 92 Legend L, 4dr
Old Dec 18, 2002 | 06:30 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I would also guess it's the headgasket if it's displacing your coolant with oil. You can replace the headgasket with the engine in the car on an inline-four, so I don't see why you couldn't do the same on a V6. Of course, you would need to know which headgasket is leaking, since you have two.
Old Dec 18, 2002 | 08:44 PM
aut0tek's Avatar
aut0tek
Oil in the floor meaning the garage floor or floor meaning the floorboard of your car?
Harry
Old Dec 19, 2002 | 06:47 AM
coco8724's Avatar
coco8724
Harry, your correct..on the garage floor, where it will set till, sub, or sell car as is[beautiful body, rotten engine]. Done a lot on engines, but no nohow to tackle something like this, pretty well by myself. What didnt get to the garage floor, and highways, ended up in the expansion tank, drained about 1 qt of sludge, but still had the looks of oil..oil floats to top of radiator.
Old Dec 26, 2002 | 02:08 PM
coco8724's Avatar
coco8724
All eyes are focused to a blown HG, which makes me feel good compared to one general trouble shooters reference on IC gasoline engines suggests cracked cylinder head[s] are most likely cause..Obviously need new HG when taking heads on and off..any thoughts about this..and if i picked up a crack in head oil galley, can it be tested for once the head is off the car???
I'm also looking for used shop manual for this 92 4dr legend...copies of oem manuals take 4 to 6 weeks..tooo long to let my ride set..
Old Dec 26, 2002 | 03:23 PM
1stGenCRXer
Most reputable machine shops should be able to pressure test your head for leaks. Call around and double check before diving too far into your engine would be my last suggestion.
Old Dec 26, 2002 | 09:06 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
i have the same problem, my coolant resevoir has some oil in it but clean oil not foamy. went to honda and asked them to check compression and everything was perfect. and that was 6yrs ago when my car was only a couple months old. it still does it though. and im not the only one i've seen with this.
