- Has anybody got his wheels painted and regretted?
- Think this is any good?
- new injectors #4 wont fire.
- troubles, turbo not spooling as usual then, "pop" - help!
- no spark? 94 integra ls
- Building Lsvtec Need Help
- Looking to become a mechanic...
- removing AC condensor fan
- Quality of Gasoline?
- Skunk2 IM throttle body
- My k20a R swap into EG pics
- civic/integra exhaust
- What to do w/ old engine
- diagram for water pump and location?
- Tranny/axle problem
- Valve lash for my b20
- newb q - how do fuel management systems work and what kind do you suggest
- Rebuilding Distributor (1989 1.5l)
- Where is the IAT Sensor plug?
- rpm's stop 5,000 ????
- ls vtec 1/4 q's
- What gauges to get?
- JDM ITR Swap...........
- ...and so it begins
- Tranny help *already searched*
- Are these turbos any good???? LOOK HERE
- '94 accord DX overheats when idling.. moving or not
- Fixing my gas gauge
- ouch
- King bearings? Your experience helps out...
- Cryogenically Freezing... Your opinions?
- Crower 403 or 404?
- '98 GSR/'92-'96 Prelude owners
- Has anyone used the cryofuzion kits
- I need some help on picking a new engine
- Gas tank prob
- engine bearings/rod bearings????
- Cheap muffler that looks+sounds good?
- RS-R Exmag Inlet question
- Transmission problem when in reverse
- Mugen P28 ecu
- 92 si with H22 help
- Swap Info on a 94 Ex
- B18C1 into a '94 Civic EG
- Idle Problem
- accord motor problem
- Tuned cold air intakes
- 15G Greddy Turbo Questions
- Gsr, Type R, H22
- B16A SiRII into a 93 Civic EX coupe
- Teg compressor issue (throw me a f'in bone)
- would the sc kits by vortech for the 99-00 si and gsr's fit jdm or older motors?
- Uberdata?
- accord - h22 distributer ?
- Hey guys...
- sound of exhaust
- blue exhaust???
- 89 Integra Timing Connector
- FMU Ratio?
- help with old 87' dx
- new exhaust system
- Car wont stay running????HELP
- All Motor Set-up for a B18A???
- Ease of SirI into 92 Civic hatch?
- turbo setup worth it?
- All motor b18c1 Hatch
- CAI - BEST........ever!
- turbo timer wont turn on???
- would you bother with a fancy headgasket?
- VSS Location
- transmission would not shift
- Hubs for an 88' HF
- obd1 transmission with obd2 engine.. any problems???
- B18C1 engine wont rev past 6500rpm
- gas smell in oil.
- The return of the monster
- DC Metro SAFC tuner
- stock piping vs intake piping
- Some more swap problems...
- ECU numbers, maybe problem...
- Nasty Shake
- Engine vibrations
- A/C with a B16 swap
- Help please....!!!
- recirculate pressure w/o an intercooler?
- my car burns oil alot :(
- Best CAI for the 02 Si
- my jdm b16a sirII took a dump :(
- Piston removal
- type r engine swap problem
- Vac Anyone
- gsr or ls tranny???
- strange
- h22 distributor problem
- Ls Engine???
- dumptube ?
- V6 in a 97 Civic EX?? Please read!!
- b20/VTEC being built/ some questions please help.
- rear camber
- Difference in fuel injectors?
- A Fuel Injector Question
- cams
- Timing Belt Broke
- fuel pressure problems
- idling problems
- Auto to 5 speed ???
- Safc or Hondata
- Please help me
- b18b running like crap(swap)
- ITR IM in '99/00 Si
- crank pulley
- h22 wiring problem
- check engine light
- skips between 2K and 3K
- Coolant leak
- Strange Vtec problem
- what kind of plugs and wires?
- buying a JDM motor
- Swap problems
- It's Alive!
- obd1 or obd2?
- Throttle body upgrade
- t3 on lude?
- 99 accord jdm h22A swap question
- all motor or turbo
- Type-R (B18C5) Swap ???????
- fuel pumps?
- gsr-turbo...EMISSIONS!?!?
- B16A swap problems
- Help anyone?? Fuel problem
- turbo or lsvtec
- Hybrid Pictures Take 2
- vacuum/idle situation on ls swap
- info about hondata kit on jdm itr
- Blue smoke on startup
- JDM Acura Legend C32A 3.2L in 6 gen accord
- Transmission Question for CRX Swaps
- Turbo people, which brand is your favorite and why?
- Honda meet in Pittsburgh May 29th
- Vortech FMU reliability
- turbo install
- Engines listings..
- OBDII H22 Chipping ECU???
- ls/vtec converson
- Success!
- Engine Problems H22A not being able to run better than a 16. Please Help
- converting a cl 3.0 to manual
- Code 20 Electrical Load Detector
- 91 acura integra problems
- Usdm B18c1 And Emmisions?
- swaps
- Question bout flywheels that's been buggin me
- Failed emissions test - "diluted sample" ??
- 1st time builder (nervous)
- Axles?
- ECU harness!!! Help phuleezz...
- Weird Swap (sort of)...
- What ecu do i need to run for a 95 ls into 92dx swap?
- B16 or B16A2
- Help with garrett turbo please!!
- B18 swap and clutch problems
- 98 integra gsr
- Building b16 in CRX si
- GSR swap.....engine won't start
- b16a swap into crx...
- throttle body b16a replacement
- Muffler??
- what do you guys know about a B18A1 swap into ek
- b16a2 into 95 civic ex
- anything missing from this kit?
- Wastegate leak
- EGT probe install tips?
- Problems with Suggestions?
- Which pistons to get?
- GSR alternator w/ 96 DX wiring harness
- Cone air filter
- H22S in 94' accord.... possible?
- 97 ls into 98 hatch...wont run...HELP!!!!!!!!!!
- New to Honda Scene...
- tricky dilemma, car wont move.
- b16 coolant hose diagram ??
- b-series
- Auto. to Manual
- obd1 dohc zc 92-95
- Hi I'm new and never worked with Hondas...
- Need a engine..
- Engine maintenance light stays on?????
- Problem with O2 sensor and a/f ratio....
- I may have messed something up!!
- **Is it worth it..for me!? my '96 d16y7 for a 91' b18a + CA$H?!
- Je Pistons ...??
- Still Having Problem, Please Read =[
- Another LSVTEC question
- Nakayama CAI
- 91civic engine into 87 crx?
- 89-90 CRX, engine swap?
- Excellent engine break in article
- BOV placement
- b16a1 swap
- My Vigor just died...
- B18C* engines, timing belt interchangeability
- d16a1
- Light Flywheel?
- Clutch question
- Why why why??
- Finding a good turbo for my h22a
- Blueprint and Balance...
- cold start problems
- lsvtec -- with auto tranny..
- d15b2 clunking when shifting into reverse 88 civic automatic
- Learning Internals
- just ordered a turbo kit.. please help me not blow my motor ;D
- typical newb question
- JDM B18C1 into a 99 EX, Legal in CA?
- GS-R Chip/Module ?'S..
- Compression test ... yikes
- Nitrous on GSR motor
- engine cutting out help need advice
- Please help with engine knock
- NSX C30A into a Legend?
- help
- Help with timing
- odd tranny problem
- Integra LS Turbo
- Odd Clutch Problem? Not Sure
- b18b swap
- o2 sensor wiring
- '97 Civic Engine Swap B16A2 -> H22A
- Serious Discussion~ K20a in a dc2
- New motor time! Hopefully
- engine code 43???? [93 Si HB w/ GSR swap]
- Valve stem seals????
- G25A 5cylinder
- Doh First post in need of help
- 96 Civic Ex 113,000 miles me want turbo
- B-series motor into a '02 Civic EX?
- Engine Harness Question?
- bored .02 over, piston ring combo?
- which ECU for 00' B18B1
- Type R motor question
- Help Me OBD2b; You're Our Only Hope!
- How do you tell what kind of ECU you need for your Engine
- b16a2 wiring harness?
- Best engine to swap into 4th gen honda accord EX
- LS/VTEC help
- weight of a b18c1?
- Nitrous System (WHICH ONE)
- 92-95 Motor swap cars
- I need B16a into my 3G Integra LS
- its Engine Swap Time
