gas smell in oil.
Old Jun 8, 2004 | 04:03 PM
nicks420's Avatar
nicks420
Default gas smell in oil.
i have a 02 accord 4 cyl. Its been turbo charged now for 4-5 months.. I run only 5-6 psi. When i change my oil, it smells like gasoline a little bit. Anybody know why?
Old Jun 13, 2004 | 06:18 AM
honura's Avatar
honura
Seni
The only thing I could think of is that your gaskets are probably messed up and need to be replaced or a seal blah blah.
Old Jun 13, 2004 | 11:51 AM
ludeboom's Avatar
ludeboom
what is your A/F stoich
have you had this setup tuned on a dyno?
~boom
Old Jun 13, 2004 | 02:09 PM
nicks420's Avatar
nicks420
well, its the fmax kit with the two additional injectors in the intake pipe. It was run on the dyno and runs between 12-11 to 1 a/f ratio. If i could figure out how to post pics i would post my dyno runs.
Old Jun 14, 2004 | 01:26 PM
tommytoes's Avatar
tommytoes
Driver
Have you done a leak down test lately?
Oil that smells like gas might be an indicator that your piston rings are going south....
Old Jun 14, 2004 | 02:18 PM
nicks420's Avatar
nicks420
no i havnt. The motor only has 20,00 miles and the turbo has only been on there for three months now. Iv never been past 8-psi.
Old Jun 30, 2004 | 05:58 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
wait,.... explain these two extra injectors on the intake pipe...
Old Jun 30, 2004 | 12:02 PM
coredump's Avatar
coredump
I second that. I think it makes more sense that gasoline is being leaked past the piston rings into your crankcase. Perhaps the high compression busted the piston ring? This is just speculation.
Old Jun 30, 2004 | 12:45 PM
nicks420's Avatar
nicks420
well, the two additional injectors are placed in the charge pipe right before the throttle body. They spray fuel when boost is applied accordingly. I run consistent air/fuel ratios. My theory is that fuel is somehow getting into the pcv hose, past the valve and into my cylinder head.
Old Jun 30, 2004 | 04:45 PM
ludeboom's Avatar
ludeboom
that is possible
what are you basing your "consistent AF ratio" on? i hope its not the colored gauge. get a wideband, they arent 'that' much money. if your running boost you should check out www.pgmfi.org they are a tuning forum that i spend alot of time learning on...i think you will discover alot of useful info.
do u have any slips for this car? curious as to what its running.
~kris
