fuel pressure problems
Old May 31, 2004 | 12:35 PM
integsracer's Avatar
integsracer
Default fuel pressure problems
ok so i got a B&M fuel presure gauge and installed it. ( the one that goes on yop of the filter) and stock read around 40psi. then i got a walbro 255lph intank pump and it shot my fuel pressure to an unstable 55-65 psi. the gauge needle would just jump back and forth really fast like crazy. so i bought a B&M fuel pressure regulator hoping it would fix it. i nstalled it and the fuel pressure stayed the same. i tried adjusting the FPR both way and it wouldnt go any lower. it would raise up but not go lower. i was getting fustrated so i put my stock fuel pump back in and now my fuel pressure is at a constant 50 psi. its steady but higher than stock. is this the B&M FPR causing this? how can i fix it? and why does my walbro pump cause so much fluctuation?
by the way, my walbro pump made a weird noise. i dont know if its normal or not. it soundes sort of like a gargling rattle sound? i dont know.
any help would be appreciated.
-Jon
Old May 31, 2004 | 03:48 PM
integsracer
i put my stock pump back on and a stock D series FPR, but now my fuel pressure is at 59. i ruined my stock gsr one so im using the civic one. is that why my pressure is so high compared to stock?
Old May 31, 2004 | 08:37 PM
integsracer
i found a stock gsr FPR and its STILL at 59psi. maybe the return line is clogged or somthing? and when i rev, my fuel pressure goes down a few psi, isnt it supposed to go up? my car is retarded =/
Old Jun 2, 2004 | 04:52 AM
sensei's Avatar
sensei
hook up a vacuum gauge to the vacuum hose that goes to your regulator just to make sure that it is getting full vacuum at idle. Your fuel pressure should never decrease as you increase throttle, if it does, this means you are bypassing too much fuel. Is the regulator one of the ones where you must cut off the top of your stock regulator to install the B&M? If it is, you probably cut the stock regulator incorrectly.
s1ngle
92+ Civic/EL & Del Sol
38
Dec 30, 2003 12:09 PM
MadMax
CRX & Pre 92 Civic
9
Oct 30, 2003 05:33 PM
StanB
7
Mar 29, 2003 10:56 PM
SIGMA CHI GUY
Mar 13, 2003 05:35 PM
ZiviCase10287
Engine Swaps, Tech & Tuning
Jan 6, 2003 06:54 PM
