B16A swap problems
Old May 24, 2004 | 05:25 PM
Splishkanake's Avatar
Splishkanake
JDM PWR
Default B16A swap problems
hey, heres the deal. I have a 91 civic standard 4spd hb. I installed a B16A a couple of weeks ago, and everything is bolted up and looking good. I did some of the wiring myself. I wired the fuel injections, V-tec, Oil pres, and Knock sensor up. Now I drive the car and it hardly goes above 2000 RPM then it falls on it's face and you have to shift or it sounds like it's hitting the rev limiter. It will only go like 50mph in 5th gear. Please someone help me out. I am desperate for help. I cannot afford to take it to a shop and pay out the @ss for work. I have called a couple of shops and they said that is sounds like a bad distributor. What do you guys think about that?
I appreciate any and all help that you guys can provide. thankyou very much.
Old May 25, 2004 | 06:36 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Is it throwing any CEL codes?
Old May 25, 2004 | 03:42 PM
Splishkanake
JDM PWR
crank angle sensor, and code 10 - iac ?
Old May 26, 2004 | 08:49 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
By crank angle sensor do you mean code 4? Helms calls that the Crankshaft Position (CKP) sensor.
Code 10 is for the Intake Air Temperature (IAT) sensor.
I've attatched the troubleshooting guides for those codes from my '93 Integra Helms manual, but I can't guarantee that your wiring will be identical.
File Type: pdf
File Type: pdf
Old May 26, 2004 | 05:41 PM
PHiZ's Avatar
PHiZ
BOOST GOD
It's your wiring. Not that that needed saying but...
hope this helps:
http://honda-tech.com/zerothread?id=650230&page=2
-PHiZ
b16acrx187
CRX & Pre 92 Civic
22
Mar 31, 2004 04:19 PM
sol woman
92+ Civic/EL & Del Sol
8
Mar 5, 2004 07:59 AM
Sharky NRK
Accord
Apr 2, 2003 12:51 PM
cpc-racing
11
Jan 14, 2003 08:08 AM
integra2316
Sep 1, 2002 10:37 PM
