buying a JDM motor
Old May 27, 2004 | 04:22 PM
ED9man's Avatar
ED9man
driver
Default buying a JDM motor
I'm planning on buying a 1st gen B16a for my CRX by the end of the summer because my D16A6 is slowly dying I think, but I want it gone anyways. I was wondering if I should do anything to be safe when I get it. Would it be worth doing piston rings, new bearings, making sure the valvetrain is all set, etc. Do they sell rebuild kits? Are the motors usually all set and in good shape? Because they claim they all have low miles but I doubt that from a 90 or 91 car. I know its a good idea to do stuff like the timing belt, clutch, pull the head off and look at the pistons, and do a head gasket. I want something that's going to last 50,000 miles with good maintanence with any internals going bad that's still driven hard on a regular basis. Also I was wondering if I ever need to get parts is everything for the B16A2 Del Sol going to do the job because its probably a pain and expensive to get parts from Japan. Thanks.
Old May 27, 2004 | 10:01 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
definitely do the timing belt and water pump. Might be a good idea to check the clutch too.
Do a compression test, if it looks good, then don't bother with the rebuild. I wouldn't even bother pulling off the head if the compression and leakdown are OK.
kazi
News & Rumors Archives
12
Nov 21, 2003 12:54 PM
Dimi
92+ Civic/EL & Del Sol
43
Sep 8, 2003 05:00 PM
ChillOutWayne
6
Apr 24, 2003 10:12 PM
doodoobrown
Engine Swaps, Tech & Tuning
Apr 20, 2003 10:01 PM
