- Autometer A/F Gauge ????
- power tech exhaust?
- does a b18a swap into a 94 hatch any different than a b18c1?
- Post Questions about engine swaps.
- How the remove my stock shift knob????
- LS/VTEC question.
- Need Help
- new muffler & exhaust
- What's This?
- crankshaft bolt
- H23 and F22A1 Exhaust Flange
- b16a vs b18c1??
- iat sensor, and funny idle
- light knocking noise
- Got My Motor In!!! Woo Hoo
- exhaust
- Adjustable cam gears.
- Injectors ticking?
- 12's anyone?
- Non to vtec
- 9k redline with turbo
- Skunk2 stage2 cams and milled head?
- zc problems need advise
- used flywheel????
- b16a1 into 91 crx dx
- Helical LSD into a Y80 transmission
- What's the engine code for 91 Civic DX?
- question about SCCA engine build
- Which valve clearances to use?
- Spoon Motor with Turbo
- need help w/ O2 sensor
- Valve Adjusting on '98 GSR w/ 64K miles
- My new toy...
- Nitrous Tuning
- need help diagnosing problem in a 88 integra
- H22A injectors.........need help
- Need gear ratios for H22 5speed trans.
- removing the cat...
- Need advice with my girlfriends car
- 1990 Acura S3 light indicator flashes
- b16a2 harness fit d98 d16y8
- ZC motor: HELP
- Is this setup possible?
- JDM in Cali
- Adjustable cam sprockets
- High idle after engine swap
- Some engine basic and buildup question :)
- What do you think of this All-engine set up in the Type R?
- I_need_interior_help
- D16Y8 head onto a Y7
- Cylinder head porting? www.airflowdesign.com
- My 240SX and my problems, help me
- GS/VTEC turbo into 91 integra
- Am i able to utilize this boost guage from a saab??
- Need help bringing a phat 3rd gen Prelude back from the dead
- Timing Belt on '98 GSR. Please help.
- Water-to-Air Intercooler Options
- AEM Fuel Rail and Injectors
- Can Intercoolers be TOO long??
- Crack In Jackson Racing Manifold
- Rattling at idle...
- bad sensor, code 10
- A/F Ratio Question
- Help
- OMG whats wrong??!!
- Help, my third gear is not pulling
- fuel expander?????????
- Civic Service Manual on EBay
- Gas Loss Problem
- Fawking lock pin...
- Code #9 need help please
- 2nd gen B16 = EG mounts??
- h22 into 94 accord?
- CRX engine swap - D16 to B16
- what is the highest octane pump gas in japan??
- Good shop in MD
- getting back that lost horsepower
- Jackson Racing SC'd Type-R
- oxygen sensor
- Where to install these gauge sensors?
- B17 = B16 Buildpath
- Closed Deck Blocks
- Crank pully help
- h22 Tranny
- Distributor Replacement
- Check engine light?
- Fluidyne is it worth it
- best engine mounts
- vtec engagement problem
- Head Gasket Install
- 92-95 Hatch question???pls Help!
- b16 to a b18 Q
- Skunk Turbo Cams or Toda Vtec Killer Cams
- nasty spark plugs
- B16 Q
- My car won't start!!!!
- Question for anyone who's ever owned a DynoMax kit.
- Drivetrain questions
- 88 CRX si - H22a swap?
- CRX 88 SI - H22A swap?
- vtec engagement
- O2 sensor extension?
- A mother needs advice for her son.
- any help or suggestions would be nice
- BAD news! NEED Help/advice!
- vafc problem :(
- exhaust diameters?
- F22 DOHC JDM MOTOR In a crx
- Rough Idle
- black specks on bumper/puffing black smoke? help..
- a/c problems... blower motor??
- b20 motor k20 head?
- B20Z into a 1993 Civic Si
- Ya, finally got pics!
- tune-up?
- MIL code 43 on a GSR....
- ABS codes for 91 Accord SE
- How to swap a H22 into a Integra/Civic (HOW TO GUIDE)
- hondata users
- some pics of my crx turbo
- How big of shot is safe on a stock Accord?
- b18b
- Engine prices
- power steering pump help..
- J30 into 5th gen accord?
- ITR intake manifold on B16A
- Alternates to swap?
- Sunroof wind noise
- K-series into an EK, someone has done it!
- Passport only clicks when trying to start
- 02 Exhaust Sensor
- runnin hot
- Tranny Swap
- 13.6 1/4's all day.
- Chilton's is a crock!
- day 1 of swap
- b20z bottom end on b16a3 (95 del sol)..how hard
- Engine swap?
- Radiator Fan stays on
- finally it starts
- why would my engine behave like this?
- MSD or no MSD
- Soft Clutch Pedal
- Valve Adjustment
- crvtec buildup
- engine has a rattle under accleration
- Just for you, Harry!
- how long did it take to get motor
- Tenzo Mufflers?
- Pulling transaxle ('92 Civic)
- OBD-II port location
- Need some Help guys
- sfc
- H22a
- Simple Wiring Q
- HP from these mods, and suggestions?
- H22 swap into Civic EX 2K
- Advanced Timing Kit?
- A question....
- Electronic Turbo?
- B20A? Anyone have any info?
- B18C1 into '94 CX hatch
- > > > Water coming.... < < <
- lets get this straightened out... does i/h/e really do anything
- b20 weight vs. a b18c1
- strange clutch problems...please help!!
- Got it dynoed, now what?
- NOS with stock civic
- turning a gs into a type r
- Turbo on 96 Civic Dx (D16Y7)
- Hisssing noise from throttle body??
- strange engine/pipe noise?
- Hesitation and Enigne Codes...
- H22A4 into Accord question
- exhaust, cam, pulley
- Wiring Harness? And/Or intake manifold?
- Where does this sensor go?
- b16a2 swap into 93 civic
- Help Quick!!!!!!! Spark Plug Wires.
- Need help diagnosing problem
- ITR 5 Lug Swap
- How much can this engine take?
- Spark plugs...
- post and polish
- b16 won't start
- Questions about Ignition
- B16 in a 93 dx hatch
- Jackson Racing Help!! Running Rich!-
- JACKSON RACING HELP!! running RICH
- timing question
- fuel injector recalibration worth it?
- integra O2 sensor wire color
- ignition questions
- Machine shops in Dallas area?
- Who makes a 10-12 lbs Flywheel????
- Check Engine Light 45
- whats the loudest vtec hi cam crossover?
- throttle cable?
- 95 gsr radiator and 2000 gsr radiator
- Radiator help
- speed sensor connector layout ... Need Help!!
- Honda Crank pully question.
- JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
- The NOS difference
- need immediate help - Check engine 54
- 92 Si won't start when hot
- 99 si axles on a 93 civic ex
- Vtec to Non-vtec conversion
- too hot...radiator
- GSR Drag Turbo in a 96hatch any issues?
- A/C Belt increase HP???
- Oil on spark plugs
- adjusting valves?
- water in oil
- How to beat SS camaro
- trans lube?
- step by step no-spark flow chart troubleshooter
- Replacing rear main seal?
- bench bleed? or full system?
- Any problems with DX tranny mated to EX motor?
- throttle body
- what does low profile tire mean?
- Transmission question
- Valve spring and ret. install
- what happened to this forum
- Damper Removal - G2 Integra
- 93 DX Hatch w/94 LS swap..Bad Gas Mileage..
- 96 civic dx fuel pressure?
- a 96 civic DX head -- to a 96-00 single overhead vtec
- Need some advise...
- do i need to retune my hondata 2b?
- brake trivilia for pro's
- Oil Leak (the part?)
- Where to check oil on manual gearbox?
- What do u guys think of this set up?
- my car overheated, plz help
- 99 Si swap Help
- B16a2 throttle cable
- Need some ideas about a swap for 2000 civic si
- head swapping?
- hydrolock 101
- Integrated Motor Assist
- 626 CEL Question
- integra fuel injection question
- LS/VTEC with a b18a??
- Throiwing my first code!
- Strange idle - check engine light...help!
- B18A1 swap problems
- High Idle?
