ITR 5 Lug Swap
Old Jul 14, 2002 | 06:17 AM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default ITR 5 Lug Swap
I want to swap the 5 lug set up over to my car and I have a few questions.
Is it all bolt up?
Do the swaps normally have ITR rims?
This last one is important, I have some 92 Civic Suspension stuff at home already (springs and camber kits) can I use this on the ITR suspension?
Old Jul 14, 2002 | 12:57 PM
qtiger's Avatar
qtiger
Front suspension should work but rear will not.
But.... why?
Old Jul 15, 2002 | 05:55 AM
The G2 Racer
Want Boost!
How do I get the rear to work?
This is how I'm looking at it. Rims, tires, bigger brakes then stock and disc in the rear for $1500. That's a wicked price.
Old Jul 15, 2002 | 06:35 AM
qtiger's Avatar
qtiger
Rear you will need ITR suspension parts.
Old Jul 15, 2002 | 02:42 PM
The G2 Racer
Want Boost!
You mean like springs and shocks correct?
Old Jul 15, 2002 | 02:50 PM
qtiger's Avatar
qtiger
Yep.
Old Jul 15, 2002 | 07:47 PM
The G2 Racer
Want Boost!
Ok. So can I run ITR springs (coil overs actually) and shocks all the way around?
Old Jul 15, 2002 | 09:15 PM
qtiger's Avatar
qtiger
Yep. Just be aware that advertised ride height will not be anywhere close to what you will see.
Old Jul 16, 2002 | 08:08 PM
The G2 Racer
Want Boost!
What do you mean? I'll be lower or higher?
Also shouldn't the itr 5 lug swap come with stock springs and shocks?
Old Jul 18, 2002 | 05:46 AM
white lightnin's Avatar
white lightnin
Its not like the swap is some package you buy, its whatever someone is selling. The type r rear lower control arms are different and thus you must use different shocks in back.
Question: Possible to use civic/integra non type R rear lcas and run different shocks. I hear peopel running type R lcas on non five lug cars, so I figure it would work.
Also why the five lug. Better stopping can be had for cheaper on 4 lugs. Plus you dont need new wheels shocks etc.
