- Coolant in cylinders
- B16 swap All shook up.
- Needing tips on starting a project
- Head bolts torque setting??
- I need help with wiring
- swap?
- welded diff???
- Using auto harness for JDM ITR to EK swap
- 93 prelude need to no what engine to put in
- d15b2 swap from d15b problems
- Build Question
- Legend engine swap
- mini me swap
- Type R Engine Harness question
- JDM ITR to EK power steering line ?
- Gsr Rebuild Swap No Start
- 2.2 misfire
- integra engine swap out with the old in with ?
- how to swap motor?
- Sequence of parts for a Daily Driven turbo build.
- integra tps sensor
- h23a motor swap for delsol
- Have 90 DA wit problems
- In the middle of replacing head gasket.
- has anyone heard of this new EZtune software or whatever it is
- 1995-1997 V6 C27 series engine swap
- problems with fire and the time
- Which dizzy(s) can we use??
- ls of trouble
- machine shops in central florida??
- quick question..h22 swap..
- machine shops in Orlando
- eg coupe with turbo b18
- teg type r. valve clearance.
- h23 vtec swap
- Need Help With Engine Sensors....
- Need Help With Engine Swap
- 2000 prelude 75 shot wet zex kit / what else do I need
- what should i do?
- b16 head year??
- Car smokes on my fresh complete rebuild... ?
- SOCAL! - Help me find a shop for my rebuild!!
- Flywheel Help Please!!!
- What's The Holy Grail of V-TEC Motors
- B18 in a F22 engine bay???
- Integra Type R Swaps
- 02 civic
- h22 head on f22 block
- accord motor swap
- vacuum guage
- Valve clearance
- Oil life reset
- Best engine swap for my del slow
- Check engine light on and D4 blinking (Help)
- 424HP 283TQ @ 23psi stock sleeves 93oct
- Torque Converter Control Valve
- 1995 accord 2.7 V6 heads
- B18C1 Conversion
- Acura CL 2.2 V-Tech
- best swap for 94 accord
- h23a swapped for h23a3, wont start, ignition trouble
- B16A PISTONS in a LS MOTOR
- CEL Intermittent
- spark plug gap
- spark plug gap
- Quick swap question..
- After swap car wont run right, IACV, o2 issues
- whats it called???!!!!!!
- are thety the same
- How hard is it to swap a h22 in a 92 civic sedan
- Venom 400 Control Module Does it work?
- shit this sucks i got a broken spark plug and porslin in my motor
- Fidanza 8lb Flywheel Trouble
- i have ecu trouble help!!!
- C1 Turbo Build
- HELP! B16a Smoking out the engine...
- integra 95 swap question
- B18B in a Eg coupe
- Apexi Neo AFC question
- anybody running e85?
- Cam Gears
- power steering pump?
- LS/Vtec Build. Advise and Opinions wanted and welcome.
- turbocharger
- B18b1
- LS/Vtec
- Radiator Options
- Wastegate Woes
- Question about my A/C
- compression
- Any ideas?
- b18b turbo setup
- I need help on the EF
- cable or hydro
- which is best for my swap
- maximum compression on a daily driven gsr
- i Just bought a 95 civic with a b18b swap in it.
- nos help
- b20b which one?
- can someone help me out here?
- Some money to spend..
- just got a b20!! NEED HELP!!
- K series
- Rev limit??
- Need some Expertise!!
- tigerjapanese.com
- how can i gain horse power with little to no cash
- b18c1 vs b18c5 vs b16a2 vs h22a2
- b18c swap help needed
- b16 block , itr pistons , gsr head .... need help
- trying to bild up my b18c1 with turbo
- Crazed and Confused.
- trying to turbo my b18c1
- 110 octane fuel
- Hi All - I need advice on WHAT O2 SENSOR to buy - brandname
- Questions about a B16A swap
- What are the current smog legal boost options???
- turbo help
- Muffler advise.
- 2000 Honda Accord EX V6 issues
- What Tune?
- H22A4 goes in and out of limp mode, PLEASE HELP
- aif/ fuel controler/hondata HELP!?
- A few n/a Q's
- Tranny
- B20b Vs B20z
- accord 99 engine swap
- Ignition Timing Help
- what is the biggest engine i can put in my hatch
- battery/alternator problem!
- need total timing
- GSR build help...
- GSR build help...
- CrVtech
- Maximum rev limiter for valves/springs etc?
- h22
- B16A LMA problem
- New Synapse BOV adapter flange. Helpful Info
- 97 civic dx help!!
- HELP WITH LMA's
- Best intake/ throtle body/ cam combo 4 a b16
- valve adjustement on F23 head?
- Launch control
- Is this possible
- help swap my stock p72 with skunk2chipped p30
- Distributor Issue
- 3.2 to 3.5L Conversion TL 03TypeS
- what engine?
- 93 Integ, w Gsr, Sk2 Int,Mugen HELP NEXT
- Debating Engine choice for swap in CRX
- intermitant tapping - 96 accord V6
- Help yo
- Best combination: head/bottom for a turbo?
- what can be done to this engine
- new to the tuner forum
- 88 acura smokes
- beef up my 88 acura legend for a sleeper
- Need a Tune
- del sol ac system
- Boosted B16a problem
- Clicking sound when engine is warm
- HELP!!!! p0505 issues
- under drive pulley install D16Y7
- Starter Problem
- Opinion On Edelbrock Performer X Turbo Kit!!
- Does Anyone Know Where I Can get honda "crate" engines???
- a good shop in MI?
- h22 into 93' dx hatch
- b16a stock crank
- got a really quick question
- what is needed for a motor swap b18 type r into a 94 civic hatch
- How would you improve a k20a?
- Help Error Code P1149 & Slipping Tansmission
- pcv hose help!?!?
- Help On Ls Into Gsr Swap
- whatu think?
- FINALLY ready for turbo!
- F22a1 To Souped Up H22
- 99 civic ex
- Clucth Question
- Check Engine Light on 02 Accord LX
- b series head on d16y7 block
- DC Sports 1 piece ceramic header install question
- Engine Oil
- Is this Gs-r set-up good for 325 whp?
- Gt45!?!?!?
- P1149 1998 Accord EX
- turbo smoke...
- obd1 motor in a obd2 car i need help badly
- K20?? 02-06 JDM Integra Type R
- Problem with my turbo "Poor man's Type R" setup... "Subey" sound
- V-tech
- B18b Obd-1 To Obd-2
- 96 Prelude Si -To swap or not to swap?
- Does any have a good video K20 head w/ k24a2 build & swap?
- vtc and tdc sigal wire
- best turbo back exhaust?
- crank pulley wabbles
- ECU codes - Long versus short
- Yeah~ [H22 Swap into DC Integra]
- Axles for b20Vtec??
- Ls Turbo Build??
- Cold Air Intake problem
- 97 accord idle vibration problem, new to forum
- Integra [GSR motor into 90 LS]
- Header or High Flow Cat
- b16a1 into 97 ek
- Need Help about changing tranny
- 1996 acura rs with 1999 gsr swap!! wiring
- help b18c1 rebuild
- power door lock issue
- Problem with SRS Light (I think!!)
- Turbo Specialties INSTALL HELP***
- o2 sensor
- Nct problems
- 2006 Honda Accord V6 6sp In To A 99 Prelude
- 2000 gsr swap into 99 ls
- BIGGGGGGGGGGG TINGZZZ 96 ls -> gsr swap?
- Need Cheap Power Out Of My D16Y8. And QUICK!!!
- head gasket for h22 vtech
- PCV system for turbo
- the best swap for my 87 crx
- starter is not working
- Will this fit?
- V-Tec Wiring Help? OBD2 to OBD1 P28 V-tec ECU
- V-Tec Wiring help. OBD2 to OBD1 p28 V-Tec
- Clutch rattle - help!!
- need help for DTC P 1751
- new plugs, wires, cap, rotor = wont start (civic)
- Budgetmobile=Project Rice (56k take a nap)
- H22 turbo parts rundown please..
- help!
- Rebuild or swap?
- Tell me more
- CTR & ITR Cam pictures needed
- h22 Vtec problem
- h22a throttling problems
- How Do I Make My 2006 Accord(auto) go faster.....just give me a list of suggestiong!!
- below horespower ratings
- Engine Harness Question
- ef8 crx f20b hybrid
- ls/vtec questions
- how to put cams in?
- h22a EGR problems
- stock fuel limits?
- Identify this engine noise!!
- b20 vtec problems
- help with b20vtec swap wiring
- What engines fit in a 92 prelude
- Honda Accord Hesitates In Gear
