under drive pulley install D16Y7
Old Aug 20, 2007 | 10:03 AM
civicbmx's Avatar
civicbmx
Default under drive pulley install D16Y7
I am going to install OBX under drive pulleys on my 98 Civic HB. It has a D16Y7 engine. I have the pulleys and belts ready to go. I am also replacing the water pump, timing belt, tensioner, and lightened crank pulley at the same time. I'm hoping to get this done in a day but don't really know what is ahead. If anyone can provide advice or tips they would be greatly welcomed. I really can't afford any snags as time is limited. I have changed the water pump and timing belt on a 90 Civic HB so I know I can at least do that, its the taking off of the pulleys I think may be an issue. Thanks.
Old Aug 21, 2007 | 06:57 AM
lkailburn's Avatar
lkailburn
college kid
get a haynes book or get the online helms. that will atlest help you out in terms of how to remove parts. the crank pully is a bish to get off because usually the big bolt is rusted on there pretty good. not to mention the 200 or 250ft/lb tq rating on the bolt lol
-Luke
Old Sep 10, 2007 | 05:31 PM
civicbmx's Avatar
civicbmx
Default thanks
I am going to attempt to do the work tomorrow so we'll see what happens.
