maximum compression on a daily driven gsr
Old Oct 2, 2007 | 07:54 AM
robmea's Avatar
robmea
Default maximum compression on a daily driven gsr
Hi I am building an EK hatch with an obd2 gsr swap. I got the car with the blown gsr so I am rebuilding it. I am going with N/A. I was wondering what the maximum compression i can safely run and still be able to use pump gas 91 or 93 octane. It is going to be a mostly stock block and head. I have heard that the highest you should run is 11:1.
thanks in advance
Rob
Old Oct 3, 2007 | 07:10 AM
primetime's Avatar
primetime
11:1 is a good number!!!
Old Oct 3, 2007 | 06:52 PM
Snoopy's Avatar
Snoopy
been there done that
11-12:1 is about the most you should shoot for. things like elevation, weather, cams, and tune play a big part.
Old Oct 4, 2007 | 11:56 AM
robmea's Avatar
robmea
thank you for your replies. I will probably shoot for around 11:1 I was just trying to get everything straight because when i rebuild the engine i want the internals to be decent so in the future I can mod it more as i get money, and i dont want to have to worry about things like pistons and such.
One more question is what bearings to go with. I plan on using ACL but im not sure if i should go with the DuraGlide series or the Race series. The car is gonna stay N/A but i just want to have a peace of mind and know that it will be strong and capable to taking alittle abuse and still last along time.
Thanks in advance for any help or replies
Rob
Old Oct 4, 2007 | 03:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would use OEM Honda bearing properly clearanced but that is just me.
Old Oct 4, 2007 | 06:16 PM
Snoopy's Avatar
Snoopy
ACL race bearings are a little looser than the normal ACL bearings. ACL's are all equivalent to honda's green or middle bearing size. if they give you the desired clearance's, use them.
Old Oct 5, 2007 | 08:15 AM
primetime's Avatar
primetime
Rob
Jdm Type R Pistons will get you a little over 11:1 with a stock headgasket! www.inlinefour.com has them including the rings for $320. i get some of my honda/acura oem and aftermarket parts from them!!
