Launch control
Old Sep 4, 2007 | 10:32 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Launch control
My local tuner is tuning my car on friday using crome and wideband.
Can i put launch control on it? does it matter what versoin of crome he uses?
Old Sep 4, 2007 | 03:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Crome has a built in two step. It wasn't available/functional in all versions of Crome. I am using version 1.2 and it definitely has a functional two step. Just make sure your tuner has all the available plug-ins as I believe it was released as a part of a plug-in instead of as an update.
Old Sep 6, 2007 | 01:29 AM
B16a2VTIguy
Built B16a
What does it mean by two step??
Also, could u explain the differance with plug in and update? I know what an update is, but would i need to buy an extra part for a plug in?
If so where can i get it?
Old Sep 6, 2007 | 07:21 AM
Provocateur
On permanent hiatus
Two step is just the term used for a fuel cutoff at a specified rpm used to launch the car.
A plug-in will modify the existing version of the program, whereas an update will load a newer version of the program. For example, you can download a plug-in that adds a boost cut, cel shift light, and other things but the version will still remain the same. www.tunewithcrome.com has all the plug-ins you need. Make sure you DO NOT update to the newest version...I have been hearing some problems about it. You can read up on it on forum.pgmfi.org and make your mind up for yourself.
