2.2 misfire
Old Nov 18, 2007 | 04:20 AM
glen53@fuse.net's Avatar
glen53@fuse.net
Default 2.2 misfire
completely rebuilt 2.2 new clutch ,piston rings everything head rebuilt compr. 170 every cylinder new plugs,wires.dist. cap all replaced.have fire to inject. good spark no.1 cylinder won,t fire at low speeds runs exect at high rpms slow to idle no. one cuts out sbitched inject from 1 to2 same thing 1 won,t fire...................help.davidson1:
Old Nov 18, 2007 | 06:28 AM
talltattoomike's Avatar
talltattoomike
ide check the cap ,rotor,plug wire & spark plug
Old Nov 18, 2007 | 07:30 AM
glen53@fuse.net
new plugs 2 differ. sets used ngk also bosch plat. new wires good spark right to injectors....car runs reall great went down road 5000 rpms each gear not a miss at all stop at light started not firing again
