aif/ fuel controler/hondata HELP!?
Old Sep 15, 2007 | 05:07 PM
dreadyboy7's Avatar
dreadyboy7
Default aif/ fuel controler/hondata HELP!?
ive been looking into some fuel management..im driving a 2000 prelude with a t3/t4.. which hondada system do i go with?? and would a piggy back unit work for my turbo setup?? ivebeen looking at the Apexi Neo AFC would that do the trick if i wanna map it out with boost? or multiple levels of boost?? thanks..
Old Sep 15, 2007 | 10:15 PM
Snoopy's Avatar
Snoopy
been there done that
piggy backs like an afc are a no go if you want reliable engine management. your best bet is to convert to obd1, chip an obd1 ecu, then tune it. each hondata system has different features you may or may not need. www.hondata.com
if you're not doing the tuning yourself, find a local tuner and see what they recommend.
