- Crome Q's
- B16a turbo problems! HELP!
- Cut-off initiated for no apparent reason
- What Timing Belt
- gs-r or b20 pistons
- Any Difference between B18C5 n B18C?
- seized motor
- E- Manage Ultimate
- need help tighten/tensioning timing belt.
- Will this matter ?
- i need help with VTEC
- Cc2-ka7
- blow by???
- which engine would it be possible to reach 500 hp in a eg?
- bearing choice help?
- Swaping in new motor, help!
- quick question about d16y7 and z6
- does anyone know!!!!!! zc
- zc! what to do?
- Strange timing issue at idle - need help.
- Engine swap
- B20A5 Build
- Vtec/cut off problem
- 99 Gsr Problems
- My Gsr Swap Cuts Out At Around 4,000 Rpm
- B18c full swap
- B16A problem. Can you help?
- Connecting Rods
- ls vtec need info for 88 crx hf
- time for boost!! turbo guys give me a list please
- i feel my b16a4 engine is low in performance
- engine swap
- ecu problem p28
- 2000 Acura Integra
- Gsr Problems! plx help...
- B16a swap Q
- Need help 06 civic bad rear bearing
- Do turbos require engine rebuilding ?
- f22 to h22 swap????
- B16A2 motor/Type-R Tranny
- considering boost...your thoughts?
- b16a2 disp. question
- idling high???
- Integra mount?
- does anybody know the specs on a h23????
- o2 sensor help!!!!
- Engine Management and Sensors
- b16 vtec not working
- need help for B series swap in EG coupe!
- Gimme Your Opinion (Turbo Guys)
- hondata question??
- Daughter totaled her Civic, need swap
- B16a2 or B18c4 head?
- LSD swap between tranny's?
- Help with replacement engine please
- noob clutch question
- turbonetics fuel management system.
- p28 chipped in b18b
- water/oil question`
- Injectors
- wut do u prefer? lsvtec or h22
- B18C1 into EM1 - what mounts!?
- Engine Swap
- *Fluctuating rpms, tick, bang & other probs- 97Civic HX
- what do i need
- 87integra dohc D series???? [Q?s re: transmission swap]
- Spark Plugs Installation Help
- 92 Integra GS - What swap will drop right in?
- JRSC 6psi plug gap ques??? DID SEARCH!!!
- 97 h22?
- question about installing b-series engine
- 86 crx swap?
- valves
- 85 Honda Civic Staying On / Cutting Off Problems
- swap
- motor problems
- car no longer rev past 3k rpm
- B18/b20?
- 6th gen accord - F20B engine swap
- Ls, Gsr rod differences
- Engine Swap in 99 EX
- auto-to-manu
- Hey-I need advice for my B18 swap in a CRX
- D16y8 Turbo
- Whats the best oil and filter for a long lasting engine?
- six- speed teg?
- swapping in a type r have some questions
- 95 Accord head swap from dx to Vtec
- what is better
- 95 Civic EX considering Engine swap
- 96 Civic engine swap?? Witch engine do I use?
- 95 accord head swap...dx to vtec
- I think I broke my driveshaft!!! Help!!
- swaping heads
- 96 accord 2.2 vtec tdc problem
- GSR Engine Problems
- V-tec does't work
- I need some help with a B20Vtec Turbo Setup
- Swapping a B20 enigine in from a D16Y5
- 93 Del sol Engine swap
- how and where do i run my vac lines
- question......
- Rough starting b18c1
- tranmission
- h22 swap..
- tuning
- Suggestions...
- changing turbos
- Help!! Non VTEC motor into EX Civic problems
- engine swaps in MD
- eg with obd2 gsr spuddering
- turbo manifold from an eclipse to a d15?
- RC injectors!!! what are they????
- your thoughts on my lsvtec plans
- B18c1 EG problems - plz help
- vtec not cracking when its cold????
- d16z6 swap questions
- b18 type r conversion
- Camshaft Does Not Turn
- Car doesn't want to start... Help!
- Turbo....oil??
- 99 accord ex-i f23A1 turbo or not, what about SMOG?
- B16a2 Mount Kit
- D16y7 swap help for a B16 or 18
- Bad boost on 245whp Sohc!
- Vaccum lines in a b18c1
- Tuning my b18c1
- Poor Man's Type R!!!!!
- Eagle Rod Oil Clearance
- Willem + SST27sf512
- Help me decipher.........
- Honda Del Sol B18C
- tiger japanese.com ???
- k24a2 swap in CRX???
- B18C in 93 del Sol
- 1999 Acura Tl 3.2 Mis fire Help
- problems with my fans
- VSS Connector
- DIY Supercharger?
- I Need Your Opinions!!!
- 90 integra to b20
- B16a boost or b18c block?
- RB26DETT 2.6L in a 89-93 240sx hatchback; Can it be done?
- b18c1 urgent help plz [Civic Swap ?s]
- H22 civic Help NO REVERSE
- b16a civic 1991
- Timing Belt for Hybrid
- DIY power increase?
- what to do
- I need to find performance parts a d15 vtech.
- need help d16z6 to usdm b16 or b18?
- Possible engine swap
- Need help with exhaust/Boosting
- 97 Jdm H22 Into 94 Ex Wagon
- 1991 LS swap
- Help with Details on a swap i have a 93 hatch and im putting a B18 andI have some ?'s
- Need help with what i need for a B18A1 swap with my D15
- need to find good place to find an h22a 92-96 for my 94 integra
- OBDI p72 - Identify...
- Hondata S200
- b20 vs LS
- b16 vtec problem
- 5k rpm rev cut? HONDATA h22 turbo
- misfiring problem
- My Project Build
- Problem When V-tec Engages
- prelude injectors????
- 97 ls turbo plugs
- Type R ring gear in LS transmission?
- N/A compressin ratio!
- S2000 slow to start and now will not turn over
- Engine revs while in park: 1999 Accord coupe
- Turbo D16 w/ stock internals
- ITR valve in a GSR head
- from d15 vtec 2 d16 a1 dohc 00"hatch civic
- need help bad!!!!!!!
- Port and Polish
- New Engine Completely, Got Questions
- engine swap 97 civic automatic d series
- What are the best cams for B16a?
- 91 Legend Engine swap
- 98 Turbo DX?
- Whats the next weakest link?
- hybrid question
- HELP what should I do next?
- overheating help!!! [94 Civic w/ 2000 B18B1]
- B18A Vtec?
- need help bad
- good head gasket for turbo?
- reading the plugs
- del slow neads k20
- b18c1 in to 93 civic coupe need some help
- 88 legand to 88 accord
- Help, my Civic is reving itself!
- Internal engine coatings
- question about swap for 93 eg6
- del sol swap
- PROBOOST PLATINUM this is that lil thang sold off ebay
- Head Work
- Type R cams
- Type R Intake Manifold
- Fuel Pump noisey
- Need Help Turboing.
- ls problems
- I Need New Tyres!!
- built loose???
- Weird thing happening to my car after track race... pls help
- Help: Identifying item on vacuum lines
- 94 Civic Si Hatchback Swap!
- head gasket?
- gsr hatch problems
- B18 swap questions
- ECU what is better Type R or GSR?
- P72 ECU WITH IMMOBILIZER How to remove it
- Hondata s200
- 97 ex ecu?
- civic/ turbo question
- gsr exhaust in civic
- Raising rev-range
- help please
- B20 Or B16
- nrg ground wire kit?????
- can I make my non-vtec B18Ba into a vtec?
- A/C PS ok with a turbo in a b16a 92 hatch?
- who makes the best Cams for GsR?
- 92 Honda Civic HB
- manual cable tranny into del sol
- Anyone know which sending unit for autometer temp gauge?
- '95 engine purchase?
- 1994 non v-tec to v-tec swap
- 1986 Accord LXi engine swap
- Pistons
- Are VTEC engines more modificated than Type-R engines?
- Built Head!
- 93 civic ex engine swap
- LS/ Vtec changing from EF to EG platform
- Cams!!!!
- gsr swap in a 91 4 door ls?
- the best engine for turbo?
- Ideas on a d16y8 Build...
- 95 dx. h22a or b16a?
- going Turbo
- crv/vtec
- new honda site WWW.B16HONDA.COM
- k20a
- Need Auto DOHC engine w/ trans
- Where to get adj. cam sprockets for 95 Legend?
- where to find the cheapest price for an type r engine
- type r engine swap in a 95 integra gsr
- will a B16A2 computer work on a.....
