My Project Build
Old Oct 6, 2006 | 06:36 PM
Redlinerz's Avatar
Redlinerz
Default My Project Build
Hey everyone I been on this site for a while now.. just always in the background reading and learning.. I am in the middle of a build (which i will be posting pics of the process and all later) and i wanted some input on what you think. What you think the HP numbers would be, 1/4 mile would be and is it good at all????? Well here it is
Head
official JDM type R head
type r cams with jg adjustable cam gears
omni power valves
portflow stiffened inner valve springs with ITR outer valve springs
portflow titanium retainers
BLOCK
95 USDM GSR block
Gsr crank polished
GSR rods
ITR Pistons
HONDA piston rings
Clevite rod and main bearings
TRANNY
95 gsr tranny
Fidanza 7lb flywheel
act 6 puk and pressure plate
MISC
AEM fuel rail, FPR, and filter
walboro intank pump
310 injectors
MSD ignition box
MSD cap, wires, and coil
Nitto Neo Gen Tires
and various suspension work
By the way this motor is going into a DA body
Old Oct 6, 2006 | 09:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What are you using for engine management?
Old Oct 8, 2006 | 02:13 PM
Snoopy's Avatar
Snoopy
been there done that
id use oem bearings since you're keeping everything else oem
