Honda Del Sol B18C
Old Oct 19, 2006 | 07:28 AM
Xcelon619's Avatar
Xcelon619
Default Honda Del Sol B18C
I'm having problem with the RPM guage fluctuating when i'm at 3-4k. I notice the care hesitating at those RPM reading? Could it be my ignition system?
Old Oct 19, 2006 | 04:04 PM
Fuse's Avatar
Fuse
any check engine lights
Old Oct 20, 2006 | 06:49 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Injectors and Fuel filter would be my first areas of investigation. There are a number of other things that you may need to consider based on what all you've done. ECU is also important. You need to elabore with much greater detail to give us enough information to help you diagnose the problem.
Old Oct 20, 2006 | 02:05 PM
Xcelon619's Avatar
Xcelon619
there is no check engine light... I just got the distributor replace like 2 months back beacuse my car wasn't startign at all.
Old Oct 25, 2006 | 03:51 PM
Xcelon619's Avatar
Xcelon619
I check most of my fuel going to the fuel injectors and still having the same problem. I just got done with the little problems. With the RPM still fluctuating with power loss, can there be problems the clutch going bad and I noitce my clucth is pretty soft and sluggished? Just need some advice before spending the money, PLEASE HELP me out!
Old Oct 27, 2006 | 07:17 AM
mberndt's Avatar
mberndt
Look for my post about loose engine grounds.
Bet this is your problem!
Old Oct 29, 2006 | 10:26 AM
Xcelon619's Avatar
Xcelon619
thanks i'll check this out
Old Oct 30, 2006 | 01:15 PM
mberndt's Avatar
mberndt
Look at the posts and lemme know if you need any specific help. It drove me crazy for 2 months until I found it was a loose ground wire.
Good luck!
Old Oct 30, 2006 | 02:34 PM
Xcelon619's Avatar
Xcelon619
i change the engine ground and my car still has the same problem. When I'm driving the car just shut off when I shift to neutral and come to a complete stop. My car jerks when I begin to accelerate and seem like it gonna turn off agian. I gonna try switch out my performance spark plugs and try to put some cheap ones in. If anyone could help me please leave some suggestion.
thanks
Old Nov 2, 2006 | 12:07 PM
mberndt's Avatar
mberndt
thanks
Ok, which "engine ground" did you change? There are more than one, so did you inspect them all? I'm not talking about the ground on the battery itself, but the various grounds in the engine compartment that ground to the engine block or the body. I'm gonna need more info. Is your car auto or manual?
If it just started happening all the time, it's not your spark plugs. Did u look for my posts?
