Internal engine coatings
Old Sep 26, 2006 | 07:37 PM
1slowturd's Avatar
1slowturd
Default Internal engine coatings
Has anyone found a real advantage to coating cylinder walls or piston tops or piston skirts? or lifter bores? Has anyone dynoed an engine before and after? Just wondering if they are worth the money especially for a nitrous motor.
Old Sep 27, 2006 | 12:12 PM
Snoopy's Avatar
Snoopy
been there done that
havent seen any dyno numbers. but, it would be a good idea on boosted and bottle fed motors. skirt coatings help reduce friction and top coatings put a reflective surface in between the heat and your piston, resulting in less piston expansion and more resistance to detonation. plus it's not that expensive to do.
